74hc4046 to replace ceramic resonator? (variable clock)
Page 1 of 1 [3 Posts]
okelk
PostPosted: Sun Apr 19, 2015 8:29 am    Post subject: 74hc4046 to replace ceramic resonator? (variable clock) Reply with quote  Mark this post and the followings unread
I've seen people replacing ceramic resonators with a lt1799...
...but has anybody here tried to do the same thing with a 74hc4046?
It is a vco with pll and has a maximum freq. of 12mhz.
It would need a few more parts than a lt1799, but it is a very common and cheap part that is available in a thrue-hole packadge.
...since it's a vco it would be easy to mix a LFO into the control voltage...
PostPosted: Tue Apr 21, 2015 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
yes I've done that for the Ek2100. I used a standard CD4046, which is a bit slower, and only later
realized I could have used a 74HC4046. It does run on 5V so I might replace it at a later time.
okelk
PostPosted: Wed Apr 22, 2015 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice.
I like the Idea of having a vco as a clock + clock dividers.
...I have some cd4046 here too, but I guess I will wait until I can get my hands on a 74hc4046 until I try it...I want to substitute a 4Mhz clock and the max. freq.@5v is only 1Mhz (or 1.2mhz...depending on which datasheet you are reading...)
