SSM2040 - need a recommendations for filter design
Page 1 of 1 [4 Posts]
jurekprzezdziecki
PostPosted: Thu Nov 03, 2016 6:47 am    Post subject: SSM2040 - need a recommendations for filter design Reply with quote  Mark this post and the followings unread
i just have one SSM2014 ic and would like to use it in a nice build.
anyone could recommend me some nice VCF design?
best J
philpeery
PostPosted: Fri Nov 25, 2016 10:38 am    Post subject: SSM2040 filter Reply with quote  Mark this post and the followings unread
Hi J,
Your subject says SSM2040 but you put SSM2014 in the post, I assume that's a type-o, Cool
My favorite SSM2040 filter, which I have had in my setup for a LONG time, is from Thomas Henry, published originally in a short lived newsletter called "Common Mode". The filter is an excellent sounding VCLPF, I love it for brass sounds, and works great for bass patches too. I think Thomas might have republished it in his BIG circuit collection book. Can't remember the title off the top of my head.
If you can't find the circuit, I have a copy of the original common mode article. I can scan it for you.
By the way, the circuit does require a tempco. Iirc it's a 1k 3500ppm.
Best,
Phil
jurekprzezdziecki
PostPosted: Fri Nov 25, 2016 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi phil,
yes it's a type-o mistake:) i would like to try this approach. i have bought many TH books but i think it could be the "filter cookbook" which i do not have.
please scan it for me. here is my email if you don't mind.
jprzezdziecki@me.com
thanks a lot
philpeery
PostPosted: Wed Dec 07, 2016 11:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi J,
I found my old, beat up copy of common mode and sent you a low res scan the article. You can also find this, and a bunch of Thomas' other designs (VCO deluxe!) in a collection called "Electronic Music Circuits: The Reprints volume 1" that was published by the gone but not forgotten Midwest Analog Products company that Thomas used to run. I had the good luck to grab a copy from Thomas before he closed up the business. Don't know if there is a PDF out that that you can download or buy. It would be great to have an electronic copy of this book, and his "Build a Better Synthesizer" book.
Let me know if you have any problems opening the PDF!
Best,
Phil
