 Forum index » DIY Hardware and Software » Musical Interfaces
Help for an analogic wind controller
Page 1 of 1 [6 Posts]
bobrock
PostPosted: Sun Feb 12, 2017 9:45 am    Post subject: Help for an analogic wind controller Reply with quote  Mark this post and the followings unread
Hi guys, i'm a MFOS fanatic from Italy and i'm searching for a schematic for a controller sax-like. Is there something similar on the net? I wasn't lucky in my search... Sad
PostPosted: Tue Feb 14, 2017 6:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I recently made a flow sensor for work with an arduino.
It's not very hard and if you think this might be something you could work on I could help you with some extra information, but it requires some work from my side.
For a start: http://dimitridiakopoulos.com/hiduino
Just let me know.
bobrock
PostPosted: Tue Feb 14, 2017 5:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Grumble, thanks for the fast reply.
i already know Hiduino. it's a midi project, when i'm searching for a project with a control voltage depending from key pressing and a gate signal. The pressure sensor only control another CV for the VCA.
Sorry for my horrible english! Embarassed
brock
PostPosted: Tue Feb 14, 2017 10:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ian Fritz designed a couple of wind controllers. The Stealth is the analog version, http://ijfritz.byethost4.com/Stealth/st_over.htm, Son of Stealth the Midi version, http://ijfritz.byethost4.com/SoS/sos_over.htm. He may not have published all the information, but there is enough to build these designs if you know what you are doing.
You might want to read his "Wind Control of Modular Subtractive Synthesis" http://ijfritz.byethost4.com/sy_close.htm as it provides a really good description of the thought behind the designs and how to get interesting sounds using the controllers.
bobrock
PostPosted: Wed Feb 15, 2017 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi brock (what a similar nick! Very Happy )
Thanks for reply! I alrerady know even the work of Ian Fritz, but i'm searching for something else. No other people made a project for an evi?
Zorn
PostPosted: Sun May 21, 2017 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Electronotes had a couple of articles on making an analog wind controller (Ian Fritz)
- EN #86 (mouth piece)
- EN #88 (KeySwitch Fingering System) < included electronic schematics, fingering charts, and a basic drawing for building the controller using wood, micro-switches and plexi-glass keys. Produced CV, Envelope, Gate and Trigger.
http://electronotes.netfirms.com
