Taplfo project
Page 1 of 1 [11 Posts]
samsam
PostPosted: Wed Mar 01, 2017 9:10 am    Post subject: Taplfo project
Subject description: help getting this things to work
Hi everyone,
I'm new to this forum and i have struggling for a while getting my taplfo to work properly.
(sorry if my english is not perfect i am from france).
Here is my problem:
I have build this circuit to have my lfo acting as a tremolo. I have two oscillators connected to my taplfo and everything seems to work well. Problem is, the tremolo only works when the square wave is selected. On every other waveshape the sound stay on and doesn t modulate.
The weird thing is that my led behave normaly on every waveshape. My ldr (in the vactrol) seems to work. When i test the resistance with my multimeter the vactrol looks ok.
If you have any clue to solve my problem please let me know.
Thank you.
PostPosted: Wed Mar 01, 2017 4:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
That is a rather odd problem, but if the vactrol seems to be working it must have something to do with the opamp section.
I suggest measuring the voltage on the non-inverting inputs of the opamps to see if they are indeed Vref (1/2 the supply voltage).
If you have scope look at the output of the first opamp to see what that is doing, with and without the vactrol attached to it.
Also, what is the voltage level/amplitude of the audio signal you are using ?
samsam
PostPosted: Thu Mar 02, 2017 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi PHobos,
Thanks for helping me.
I have 3.36 volts on pin 3 of both opamp (tl071).
I don t have any scope to see the output of the first opamp.
I'am using two batteries for those circuits.
One 9 volt battery regulated to 5 volt to supply the oscillators and the taplfo
A second 9 volt battery (with vref) to supply the opamps section.
Do you think i should only use one 9 volt battery, and create the 5 volt and vref for the 9 volt ou of it ?
PostPosted: Thu Mar 02, 2017 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
3.36V seems a little bit low, although it could be correct if you happen to be using a rechargeable battery.
But it doesn't matter much for this circuit as long as it is around 1/2 the supply voltage.
using 2 batteries is ok as long as you connect both GND/0V connections together and it might even give you less noise.
Actually looking at the circuit again that doesn't even seem to be necessary since you only have an optical connection
between the circuits.
the weird thing is, as you already mentioned:
my led behave normaly on every waveshape. My ldr (in the vactrol) seems to work. When I test the resistance with my multimeter the vactrol looks ok
It is a rather simple circuit so if that part works there isn't much else that could be wrong. Without a scope it is going to be
more difficult to determine what causes the problem but you could listen to the output of the first opamp, it should be the
same as what you put into it, with and without the vactrol connected.
samsam
PostPosted: Fri Mar 03, 2017 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your reply.
I have ordered a new taplfo and some vactrol (xvive) to see how my circuit behave with new parts.
The taplfo chips that i have behave strangely sometimes.
I'll let you know if a new vactrol and pic solves my problem.
Thanks for your help.
samsam
PostPosted: Fri Mar 03, 2017 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Problem solved! In the schematics the second opamp is not connected to +9 and 0. I just tried this connection and it works now.
PostPosted: Sat Mar 04, 2017 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah that will help a lot Laughing
In the schematic a dual opamp is used which only has 2 pins for power so that makes sense.
Sometimes power pins aren't drawn at all so keep that in mind.
samsam
PostPosted: Tue May 02, 2017 7:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everyone,
I ll keep posting under the same thread because i'm still having issues with my taplfo project.
I have made two circuits of this tremolo and both of them are in sync with each other, wich is what i wanted.
both of them are controlling some oscillators.
My problem is that they dont deliver the exact same voltage to the vactrols wich results in one oscillator being louder than the other one.
I mesure 4,11 volt on the output led of one circuit and 4,20 on the other circuit.
The weird thing is that the led showing the higher voltage is the one that shine the less. I thought it would be the opposite.
Also i have measured different voltage on pin 5 of the chip.
1,67 volt on one chip and 1,40 on the other.
Both circuits are the same so i don't understand how i can solve this.
If you have any ideas let me know.
Thanks
Audio files: 297
PostPosted: Tue May 02, 2017 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
All vactrols are different ... LEDs are not voltage controlled but current controlled ... so the one with the higher voltage gets less current ... apart from that the LED efficiencies are probably not the same, and the LDRs will almost certainly not be the same ... you could try to change R11 or R12 to make the circuits more equal ... but still they maynot have the exact same curve then.
Point 5 of the PIC? that seems very low ... I'd have expected 5 Volts ... is the supply voltage of the PIC really 5 Volts?
samsam
PostPosted: Wed May 03, 2017 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Blue Hell for the reply.
I have tried a new circuit (with another vactrol) on the breadboard and it seems to work better. So yeah probably that vactrol behave differently.
So i will try to desolder and swap the vactrol for another one or redo the all circuit.
About voltage i have :
5 volt on pin 4
2,53 on pin 5
Yes the supply for the circuit is 5 volt.
I have started electronic 3 month ago and it's really confusing!
samsam
PostPosted: Wed May 03, 2017 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok so i have desolder and swaped vactrols and it works fine now.
Also i didn't notice at first but the two vactrols i used at first were not even the same brand...
