Will Schorre (Lorre Mill) simple enveloper
Page 1 of 1 [2 Posts]
Laihal
PostPosted: Thu Feb 13, 2020 9:12 am    Post subject: Will Schorre (Lorre Mill) simple enveloper Reply with quote  Mark this post and the followings unread
curious if anyones attempted to breadboard these? how did you like the results?
http://lorre-mill.com/2016/07/24/Some-Thoughts-on-Envelopers.html
http://lorre-mill.com/2018/09/09/more-on-simple-envelopers.html
not sure what i was expecting but i found that my build was more or less directly routing CV which was a bit dissapointing but i have a feeling my schematic was just off - just realizing as i write this that i should have had a photo of it prepared to share. oops. will update shortly
also - this isn't strictly based on CMOS but i understand the double knot and many of lorre mills other builds are - does this fit within the lunetta canon or is this an inappropriate place to post about this? thanks
dk
PostPosted: Sun Apr 05, 2020 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Which one did you breadboard?
