Midi thru trouble
Page 1 of 1 [6 Posts]
Derop
PostPosted: Fri Oct 01, 2021 8:04 am    Post subject: Midi thru trouble Reply with quote  Mark this post and the followings unread
Hello community. I am struggling with this project a lot and it seems nothing is working. Basically i used this schematics, followed it 100%, i also contacted the creator who told me it would work fine. But it doesn't want to Sad
To test it i use esx1 as master and pass the signal to minilogue xd via this midi thru.
I ve done ton of research, i used different schematics, different opto but still nothing.
I power it using 5v cellphone charger. I even tried 9v battery brought down to 5v with 7805, but nothing.
Any ideas?
 Filesize:  123.68 KB
 Viewed:  223 Time(s)
ixtern
PostPosted: Sun Oct 17, 2021 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
For me the hardest thing was to find pins 4 and 5 on MIDI socket - pinout is from the front or from behind? So attaching properly labelled pinout.
I had used some different values for 6N138 but as it not worked reliable for me (maybe because I'd not used Schmitt triggers), I had switched to 6N137.
Here is my schematic with 6N137 which I've used in two synthesizers so far.
 Filesize:  23.26 KB
 Viewed:  3510 Time(s)
 Filesize:  200.26 KB
 Viewed:  3509 Time(s)
 Filesize:  106.25 KB
 Viewed:  224 Time(s)
Derop
PostPosted: Sun Oct 17, 2021 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much for your reply! In fact... from what you are saying.. i must had soldered the 4 and 5 pins incorrectly. I will try changing them and update the topic
Derop
PostPosted: Sun Oct 17, 2021 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
And yes!!! you were 100% right, pins 4 and 5 soldered incorrectly . It solved all my issues. It works perfectly now. Iam sooo grateful!!! Thank you so much!
PostPosted: Sun Oct 17, 2021 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have lowered the resistor designated as R101 in your schematic to 68 ohm and put an LED in series with that resistor so I have an indicator if the midi is coming in.
my synth
ixtern
PostPosted: Mon Oct 18, 2021 1:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Clever solution. But I prefer more predictable design, like in my second schematic - separate LED drivers after optocouplers.
