Streaming now
Performance Macro across several slots, possible ?
Page 1 of 1 [2 Posts]
chapelier fou
PostPosted: Wed May 29, 2024 1:34 am    Post subject: Performance Macro across several slots, possible ? Reply with quote  Mark this post and the followings unread
Let's say I want to control the filter cutoff freq on 2 synths that are on two slots.
Can it be done with one knob ?
The only way I can see is to get thru a CC message, am I missing something ?
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sun Oct 27, 2024 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey!
1. Morph > Example: Assign morph to modwheel and adjust the range on the cutoff for each slot. Then make sure the 2 slots are active / Top and bottom LED are on. This solution do not require extra pathching.
2. Send real time modulation by CV to BUS 1/2 or 3/4 to the second slot. If the filter module used have CV In for cutoff parameter.
