Chuck setup: dropout
Page 1 of 1 [3 Posts]
rhenninger
PostPosted: Sun May 04, 2025 9:40 am    Post subject:  Chuck setup: dropout
Subject description: Simple alsa cli environment ok for csound, fluidsynth, but not chuck
I am setting up a minimalist computer music environment for myself on alpine linux using only alsa and cli on a single user 86_64 system: as simple as it gets.
I built ChucK with the 'linux-alsa' flag, all tests passed, and install worked fine.
I have had no trouble using csound or fluidsynth this way, but I cannot get ChucK to run without significant dropout in playback - even for a simple sine wave:
Code:
SinOsc s => dac;
440.0 => s.freq;
2::second => now;
I have tried numerous sample rates, buffer sizes and numbers and devices and priority levels. Here is a sample (any combo of these still has dropout):
doas nice --20 chuck --dac:2 --srate:48000 --bufsize:1024 -bufnum:16 --verbose
I have to think that this is a parameter problem, but I can't find any info on-line ideas yet that I haven't already tried. What am I missing?
Attachment has Chuck --verbose:2 feedback
chuck_chatter.txt
 Filename:  chuck_chatter.txt
 Filesize:  2.15 KB
 Downloaded:  109 Time(s)
Richard Henninger
nelsonpence
Audio files: 9
PostPosted: Sun May 04, 2025 6:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try
Code:
doas chrt -f 90 chuck --dac:hw:2,0 --srate:96000 --bufsize:256 --bufnum:8 --silent
rhenninger
PostPosted: Mon May 05, 2025 2:06 pm    Post subject:  Gave it a shot
Subject description: Followed suggestion and several variants: no joy
Thanks for the suggestion. I was reluctant to use chrt since it doesn't come with Alpine initially. 'chrt' is available by installing the util-linux-misc package which overwrites the softlinks of many other provided busybox implementations.
Still, since this is an experimental installation, I went ahead and loaded the package so I could give your suggestion a shot. Not sure why you had --silent in the cmd, since that suppresses the sound output. Removing that and playing with different srates, bufsizes and bufnums all yielded the same result.
Since raising process priority hasn't affect the output, I'm thinking the problem lies elsewhere: sample format, perhaps? Unnecessary threads in a single user cli environment? But I don't see command line options for controlling these.
Csound and fluidsynth have just worked with alsa. I wonder if the problem lies with RtAudio itself. Maybe I'll experiment with Stk to see if that has issues too.
Richard Henninger
