Monokey velocity output
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Sat Nov 26, 2005 10:19 pm    Post subject: Monokey velocity output
Subject description: dead in low postion
The Monokey module lets you duplicate the keyboard response of some old monophonic analogue synthesisers. For example, the Minimoog had low note priority which means if you hold down two or more keys at once, the pitch will be that of the lowest key. This, combined with the single trigger envelopes, was a big part of many players technique.
Anyway, the bug is that the velocity output goes dead in the low position.
OS/Editor Version 1.32
See attached patch.
MonokeyBug.pch2
switch to LOW mode to see bug
 Filename:  MonokeyBug.pch2
 Filesize:  1.11 KB
 Downloaded:  1800 Time(s)
Tac_Evaworcim
PostPosted: Tue Jan 17, 2006 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Verified
agreed..
BUG!
varice
Audio files: 29
G2 patch files: 54
PostPosted: Wed Jan 18, 2006 7:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
This bug was not fixed in the 1.40 release Exclamation Question
varice
