Maths >= ==
Page 1 of 1 [3 Posts]
pereshaped
PostPosted: Thu Sep 24, 2009 10:44 am    Post subject: Maths >= ==
Subject description: Maths problem
Is there a cheap quick way to accurately emulate the operator == for level detection? I had a look in the archives but could not find an obvious solution.
There is only a >= operator for level detection. I can get round this but it is cpu intensive.
I'm still in Barcelona so have not been able to try out my new G2 or the expansion board, so am using the demo software (bit cranky isn't it?). There seems to be a limit of how many modules ( indpendant from CPU load) you can have on the screen before it starts crying.
Saludos, Pere
Audio files: 297
PostPosted: Thu Sep 24, 2009 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Pere
There is no direct module ... but for instance take a mix2-1B with one of the inputs set inverting and route the output to one of the value switches, with the ctrl value set to zero. When you'd want to check if something is equal to a constant value use a value switch directly.
pereshaped
PostPosted: Thu Sep 24, 2009 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan, perfect! , thank you very much.
