my first project
Page 1 of 1 [10 Posts]
neo644
PostPosted: Sun Aug 21, 2005 11:18 am    Post subject: my first project Reply with quote  Mark this post and the followings unread
hi.
i'm going to build this VCO as my first proyect and hopefully it will be driven by a ribbon controller to make some sort of electro-theremin or tannerin.
though i have some trouble fully understanding its construction.
what type are the potenciometers to control the frecuency (coarse and fine) ? i mean log or linear, or what will be best?
where are they actually conected in the board? i have figured out where the "course" pot is connected, but the other one is connected to a 2M resister which has no name in the schematics and i cant seem to find it in the pcb. kinda lost here.
and thats it for now. i'm also confused respecting the outputs. can i plug in an output directly a pair of earphones and will the volume be okey? or do i have to build some sort of VCA to go with this?
thanks in advance, i have found this forums to be very usefull as well as the information on this site! Smile
PostPosted: Sun Aug 21, 2005 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
You did see this one:
This oscillator is NOT temperature compensated so it will drift.
This makes this module less useful in the long run if you are planning to play "real notes" with it.
PostPosted: Sun Aug 21, 2005 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
This VCO might be a bit better:
http://www.paia.com/9720.htm
Too bad Tony Allgood has discontiued his brilliant VCO.
However, a company in the US has bought the manufacturing rights to his Oakley Modular System.
http://www.ear-group.com/oakley_start.html
They already have a few modules in production. These will be made both for the MOTM and the Doepfer systems.
The wonderful Wavefolder is already in production
http://www.ear-group.com/oakley_wavefolder.html
Tony can still be found at http://www.oakleysound.com/
It makes a lot of sense to get a VCO, VCF and some enevelope generators. LFOs are cool too. I consider that a basic system.
dnny
PostPosted: Sun Aug 21, 2005 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi neo644
if you want temperature compensated VCO whit very good PCB layouts, panel wiring diagrams and all.
try this one -
VCO
you can also Purchase the pre drilled PCB for 20$
but if you don't mind about drifting - your link will do the trick
hope this helps
daniel
www.koelse.org
flickr: cable porn group
dnny
PostPosted: Sun Aug 21, 2005 2:52 pm    Post subject: Re: my first project Reply with quote  Mark this post and the followings unread
normally linears for pitch control
neo644 wrote:
where are they actually connected in the board? i have figured out where the "course" pot is connected, but the other one is connected to a 2M resister which has no name in the schematics and i cant seem to find it in the pcb. kinda lost here.
the fine tuner pot is not marked on board so its kind of extra thing - but as you already know the coarse pot goes to red spots and the center of fine goes to violet spot (picture on end of this post)
neo644 wrote:
and that's it for now. I'm also confused respecting the outputs. can i plug in an output directly a pair of earphones and will the volume be okey? or do i have to build some sort of VCA to go with this?
from the output you get sound to headphones but you might want to make headphone amplifier VCA´s are fine also and you can later experiment more whit VCA´s
yes i think the same - this forum is great. you have come to the right place
welcome
daniel
 Filesize:  11.19 KB
 Viewed:  11063 Time(s)
www.koelse.org
neo644
PostPosted: Sun Aug 21, 2005 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
that looks good elektro80, but i'm not looking for a kit Razz
and dnny that vco looks much better and fully explained! thanks alot, i'm going to build that one instead!
adios
neo644
PostPosted: Fri Aug 26, 2005 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
hey
i'm back because i'm having some trouble obtaining all the parts since i live in argentina.
i couldn't find these parts:
LF442 (can't i use a TL082? what is the actual diference?)
LM13700
MPF102 (it says you can use a 2N5457, but i have some trouble also finding this one, are there any other options?)
is there any other model that could replace these?
well, thanks again
dnny
PostPosted: Fri Aug 26, 2005 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
neo644 wrote:
hey
LM13700
the following components can be used instead
LF442 =
LF412
LT1057
LT1113
LT1457
OP215
TL092
TL082 but not TL082M (comes in U package -10 legs)
LM13700 =
LM13600
NE5517
NTE870
and MPF102 =
BF256A
2N5457
PN4416
J202
2N5951
2N3819
here is a link to another topic on substituting IC´s
and link to MPF102 substitutes.
hope this helps -
and if you just can´t find any of these. im sure we can figure out something
daniel
www.koelse.org
DrJustice
PostPosted: Fri Aug 26, 2005 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi neo644!
Some good info right there from dnny.
I'll just add that http://www.digikey.com/ has all of LF442, LM13700 and MPF102 in stock. Is it an OK option for you to order from them?
DJ
neo644
PostPosted: Fri Aug 26, 2005 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow dnny thanks alot!!
i'll look into it and find out what i can get over here at a reasonable price.
DrJustice, sorry but i cant order international, that would be just too expensive.
adios
