Ivity
Joined: Dec 29, 2005 Posts: 233 Location: Moscow, Russia
G2 patch files: 57
seraph
Editor
Audio files: 33
Posted: Sun Aug 27, 2006 10:06 am Post subject:
Re: High-quality swedish assembling? |
Ivity wrote: |
is that an ironic remark  _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
Tim Kleinert
G2 patch files: 236
Posted: Sun Aug 27, 2006 10:14 am Post subject:
Stuff like that isn't anything unusual. Most synth manufacturers are always in a hurry. So it's not uncommon to find errors in the PCB design in a stage of development when it's already too late (eg. a batch of boards has already been produced), making the need to cut traces and/or solder bridges. A newer production run might have these errors corrected, but that doesn't keep the manufacturer from using the old ones, with the kludges added.
However, these kinds of hand-made alterations are safe and nothing much to worry about.
Anyway -I wonder why folks buy into this "swedish build quality" thing. Isn't it obvioulsy just clever marketing by Clavia? I mean: We've had so many reports about sticking buttons, the super-flimsy alpha-dial knob (one of mine went and is about to go again), humming PSUs etc.. I've owned several different Clavia instruments and I don't consider them badly made, but I think they are outstanding either. I guess it's the metal casing, which gives a subjective sense of robustness -but that's purely psychological, as it gives no clue about the quality of the parts inside. Which, in the case of Clavia, are decent middle-range stuff, but nothing to be proud about.
Fact: Comparing Clavia synths directly with similarly priced synths of other manufacturers doesn't reveal any superiority in terms of build quality.
Maybe it's the red color?  |
Ivity
G2 patch files: 57
Posted: Sun Aug 27, 2006 10:43 am Post subject:
seraph wrote: | Ivity wrote: |
is that an ironic remark  |
Of course it's ironic remark, Carlo
tim wrote: | Stuff like that isn't anything unusual. Most synth manufacturers are always in a hurry. So it's not uncommon to find errors in the PCB design in a stage of development when it's already too late (eg. a batch of boards has already been produced), making the need to cut traces and/or solder bridges. A newer production run might have these errors corrected, but that doesn't keep the manufacturer from using the old ones, with the kludges added.
I know about this kind of things, Tim
I simply wanted to offer one's mite in destroying of the myth of "swedish build quality"
P.S. The most funny thing is, that I have the latest hardware revision 1.5  _________________ Igor
www.myspace.com/phoiod
www.bl-project.com/Ivity.html |
dasz
Audio files: 29
G2 patch files: 56
Posted: Sun Aug 27, 2006 3:46 pm Post subject:
Looks like Clavia needed to patch something. They used the Green (User1) cable.
I had several sticky buttons and it is a result of the machineing process (when the holes for the buttons are etched out fo the metal). Little bumbs remained where the cut was started and ended.
The procedure is a little risky as it involves removing the panel circuit board which is heavy (and could bend and break if you are not careful) due to the number of LEDs buttons and knobs on it. Then I just filed the imperfections dowm.
Reassembly is tricky as all the buttons and leds must be perfectly aligned (for me I needed to put the metal case on it's side (with the pitchstick and modwheels pointing up) - otherwise other buttons could get sticky.
/Dasz |
cebec
G2 patch files: 31
Posted: Sun Aug 27, 2006 4:23 pm Post subject:
Ivity wrote: |
P.S. The most funny thing is, that I have the latest hardware revision 1.5  |
I was told (by Alexander at Clavia) this number refers only to the front panel graphics (revision number). |
sheridan
Joined: Jun 05, 2005 Posts: 473 Location: London, England
Audio files: 27
Posted: Mon Aug 28, 2006 4:54 am Post subject:
Well I sure am pleased that I got the G2 engine with no buttons to become sticky.  _________________
Sheridan
http://www.nitetimeproductions.co.uk |
Ivity
G2 patch files: 57
intoxicat
Posted: Fri Sep 01, 2006 12:48 pm Post subject:
still my engine sometimes randomly stops producing sound untill rebooted.. i think i would rather have a sticky button than this.. although its a small sacrifice for the sheer possibilities of this machine... |
sheridan
Audio files: 27
Posted: Fri Sep 01, 2006 5:45 pm Post subject:
intoxicat wrote: | still my engine sometimes randomly stops producing sound untill rebooted.. i think i would rather have a sticky button than this.. although its a small sacrifice for the sheer possibilities of this machine... |
Mine doesn't lose its sound, but it does lose its USB connection fairly often... still as you say, it's a small price to pay.  _________________
Sheridan
Posted: Mon Sep 11, 2006 5:45 am Post subject:
My own immediate association to my country and "build quality" is sweaty labour as you assemble an IKEA shelf. I've lost most illusions about Sweden being particularly good at health care, engineering etc.
BobTheDog
Audio files: 32
Posted: Mon Sep 11, 2006 8:18 am Post subject:
Antimon wrote: | My own immediate association to my country and "build quality" is sweaty labour as you assemble an IKEA shelf. I've lost most illusions about Sweden being particularly good at health care, engineering etc.
/Stefan |
Your'e still pretty good at snow though
Andy |
sheridan
Audio files: 27
Posted: Mon Sep 11, 2006 9:34 am Post subject:
BobTheDog wrote: | Antimon wrote: | My own immediate association to my country and "build quality" is sweaty labour as you assemble an IKEA shelf. I've lost most illusions about Sweden being particularly good at health care, engineering etc.
/Stefan |
Andy |
... and women, surely?  _________________
Sheridan
Posted: Mon Sep 11, 2006 10:22 am Post subject:
sheridan wrote: | BobTheDog wrote: | Antimon wrote: | My own immediate association to my country and "build quality" is sweaty labour as you assemble an IKEA shelf. I've lost most illusions about Sweden being particularly good at health care, engineering etc.
/Stefan |
Andy |
... and women, surely?  |
Thanks for cheering me up!
pauldirks
Joined: Dec 19, 2005 Posts: 24 Location: vancouver, bc
Posted: Tue Sep 12, 2006 12:54 pm Post subject:
So it's not just me! Actually- it's not that big a deal- a quick reboot and everything is fine again. Still loving this baby.
Paul _________________ ------------
Bishop & Mulholland- Electro Soul
https://soundcloud.com/bishopandmulholland
Nord G2 Keyboard
E6400 Sampler (2)
Cubase, RME Hardware |
dasz
Audio files: 29
G2 patch files: 56
Posted: Tue Sep 12, 2006 2:37 pm Post subject:
Hey Paul,
we should hook up again. I know another G2 owner (analog assailant).
OT -- if anyone in the Vancouver, BC area is looking for a G2 keybaord, I know a guy who is selling one (it's not me, of course -- I'd never let go of either of my G2's)
/Dasz
ps.: Time for a new avatar. |
T7
Posted: Wed Sep 27, 2006 1:52 pm Post subject:
Hi all,
Anyone know if the plastic part of the G2 switches is replaceable? My brand new G2 has several deeply scratched switches.  |
T7
Posted: Thu Sep 28, 2006 9:34 pm Post subject:
Anyone have any experience with this? |
cebec
G2 patch files: 31
Posted: Fri Sep 29, 2006 5:57 am Post subject:
Hi T7. Is it brand new, i.e., from a store? Is it under warranty? You could try contacting Clavia support. Or the store you got it from. |
T7
Posted: Fri Sep 29, 2006 1:43 pm Post subject:
cebec wrote: | Hi T7. Is it brand new, i.e., from a store? Is it under warranty? You could try contacting Clavia support. Or the store you got it from. |
Yeah. I just purchased it brand new from Musicians Friend. |
kvnvk
Posted: Fri Sep 29, 2006 4:28 pm Post subject:
urgh... Musician's Friend... most of the time I haven't had any problems with them but I did get two patchbays at seperate times which were bent/warped sideways... like they had a stack of them fall off a high shelf onto the distribution warehouse concrete floor, at least that's what I imagined happened to them. also possible you got a return they sold as new. |
