agoostus
Posted: Wed Oct 11, 2006 2:47 pm Post subject:
furby circuit bending switch questions Subject description: ? |
I have been circuit bending a furby, and would like to install a switch to turn the] glitches on and off, the only thing is I am not sure if a resistor is needed and if so how do I know what kind.... any tips would be cool.
thanks
agoostus |
agoostus
Posted: Fri Oct 13, 2006 5:57 pm Post subject:
furby circuit bending switch questions |
wow,
I didnt think this was that difficult a question, I thought the answer was a simple explanation, but i guess it has many people stumped....well I hope someone knows....
thanks
agoostus |
Joined: Apr 03, 2004 Posts: 24423 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri Oct 13, 2006 6:16 pm Post subject:
And they didn't even say either, bad manners
Furby ... it is that greyish hairy toy thing that goes making sound and moves when it hears you, right ?
I've really no idea what's in it, so I wouldn't know what the switch needs, but it sure made funny sounds, if it is what I think it is. Did it do glitches, don't remember that, it spoke, sort of ...
Is this maybe a sort of a "standard" bend and described on some website ? _________________ Jan
agoostus
Posted: Fri Oct 13, 2006 8:15 pm Post subject:
well |
well I searched for info on bending furbys on the internet and it made reference to some certain vague areas that could be used to access hidden glitching and/or looping effects, and just started connecting different parts to eachother. the results were very drastic, including glitching random sounds, beeps, distorted voices...etc.... but I'm just not sure what I need to do to attach a switch.....I also would like to install an output jack |
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
Posted: Sun Oct 15, 2006 9:14 am Post subject:
If the glitch bends work by just shorting points together, then i don't think a resistor is required, just add a switch.
And for the output jack, try to connect a jack across the exixting speaker, if it is too hot (loud / distorted) the ad a small resistor, or even better a small trimmer resistor.
This site :
http://www.oscillateur.com/cb_faq.php
Has good info on adding output jacks
Good luck with the furry fellow  _________________ Stay Cool
Mikael
http://www.mikmo.dk |
agoostus
Posted: Tue Oct 17, 2006 9:11 am Post subject:
thanks for all the info this definantly helps
agoostus |
