Divide By 1.5
Page 1 of 1 [2 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Thu Feb 16, 2006 3:12 am    Post subject: Divide By 1.5 Reply with quote  Mark this post and the followings unread
Some old analog synthesizers, like 70's Rolands and the CAT, utilised inexpensive digital divider chips to produce sub octave waves.
Here is a variation, the second flip flop and gates produce a divide by 1.5 mode, so if you feed in an E, you get an A out. Unlike the divide by two, the wave also varies shape with PWM.
You might find use for this in complicated sequencer time base patches as you can switch the ratio with a control signal.
div1.5.pch2
divide F by 1.5
 Filename:  div1.5.pch2
 Filesize:  1.73 KB
 Downloaded:  1860 Time(s)
Audio files: 297
PostPosted: Thu Feb 16, 2006 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice trick !
