 Forum index » Instruments and Equipment » OSX as a music workstation
UGH! Micro Mod and Midi in OSX
Page 1 of 2 [36 Posts]
micah
PostPosted: Fri Mar 10, 2006 6:29 pm    Post subject: UGH! Micro Mod and Midi in OSX Reply with quote  Mark this post and the followings unread
OK, Just got the gen 1 micro mod.
I am an experienced synthesist and studio owner but for some reason I cannot get the MIDI setup working in the OSX beta editor. I've tried 2 different USB midi ports. There isn't even an error message. It just says "Looking" and then "Still Looking" and never stops looking. I assume the PC IN port goes to the MIDI IN of my interface. I can't figure it out.
Any help would be much appreciated.
Micah
PostPosted: Fri Mar 10, 2006 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
OS X? Which version? Which mac? Which midi interface?
Flickr
micah
PostPosted: Fri Mar 10, 2006 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, good point. Sorry>>
OS: 10.4.5
MAC: 1.5GHZ Powerbook G4
MIDI Interfaces: Evolution X-Session, Edirol PCR-M1
PostPosted: Fri Mar 10, 2006 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am using a dedicated mac for the editor app and a battered midisport thingie for midi. I don´t think I can easily debug this one. I guess you have already checked the cables and whatnot?
Flickr
micah
PostPosted: Fri Mar 10, 2006 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, i've checked all the cabling, switched it etc. also looked for other posts with the same problem.
I also tried a Midisport. Does the Midi Setup in the editor usually give a notification if things aren't set up properly? I mean, it just keeps on searching for it.
PostPosted: Fri Mar 10, 2006 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Searching, that;s what it does when it can't finf the synth, and searching stops when it found it. Not very informative indeed.
Did you check the midi ports to be working for other purposes ?
Do you have a sequencer program installed maybe that claims all midi ports it can find ?
micah
PostPosted: Fri Mar 10, 2006 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, i hooked it up to logic and the MIDI IN was working fine - I was able to play the patches. Is the PC IN/OUT like a regular MIDI port? I assume I cannot hook the editor up to the MIDI ports on the Micro Mod but only to the PC in/out. Right?
All My MIDI ports work fine. Very Strange.... and frustrating
PostPosted: Fri Mar 10, 2006 8:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Assumption correct, can feel your frustration, it can work, it can be a long search sometimes though, on a PC as well. There is http://nm-archives.electro-music.com/010_NordModular/018_FAQ/ but it has no OSX section on connection trouble.
micah
PostPosted: Fri Mar 10, 2006 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks jan, appreciate your help
best,
micah
www.mekmusic.com
www.kamoni.net
micah
PostPosted: Sat Mar 11, 2006 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm wondering if there is a problem with them PC IN/OUT ports. Is there any way to check these without using the editor?
PostPosted: Sat Mar 11, 2006 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe .. when you have a software that can act like a midi spy. I'm not 100% sure but I think the MM sends out some sysex repeatedly to it's PC port to invite a conection with the editor. With some effort I think I could come up with a sysex command that you could send to the MM to which it should reply then.
For a PC midi-ox would be a good program, but for the Mac I wouldn't know.
micah
PostPosted: Sat Mar 11, 2006 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, you sure are right. plugging the PC out into the MIDI in port delivers a constant MIDI led.
I wonder, is there a way to factory reset the micro? Or something? Man, I cannot figure this out Confused
PostPosted: Sat Mar 11, 2006 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't think the problem is with the micro actually ... but it would be best to check that of course ... do you have another computer somewhere to try, maybe a friend or a neighbour ?
micah
PostPosted: Sat Mar 11, 2006 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
HA! I got it!
Oh man, I am way too embarrased to even describe what the problem was, and i'm very sorry for wasting anyone's time Embarassed
PostPosted: Sat Mar 11, 2006 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Good !
but you _must_ tell Very Happy
PostPosted: Sat Mar 11, 2006 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
(just to avoid others making the same mistake :-)
PostPosted: Sat Mar 11, 2006 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
micah wrote:
HA! I got it!
Don´t tell us, we already know you have gnomes inside your mac.
Flickr
Gothboy
PostPosted: Sun Mar 12, 2006 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let me guess....You had the micro plugged into to like, Port 7 on the midisport and didn't realize you had to have it on one of the first 4 ports? This is what I did the first time around and nearly went mad.
Apple Mac Pro 2019 3.2 GHz 16-Core Intel Xeon W
96 GB Ram
15.6 Sequoia
Novation SL49, Behringer 2600, Crave, Edge
Mophox4, Nord Lead 2,Modal electronics Argon 8m, Roland System 1, Novation Nova, Nord Micro modular, Korg Radias, Roland d-05, Yamaha A3000 sampler, Novation SL MK2 and Remote Zero controllers, Arturia Beatstep and SparkLE, Korg ER-1, Unosynth
Dymaxion Vehicle Music at www.dymaxionvehicle.com/
cappy2112
PostPosted: Sun Mar 12, 2006 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
micah wrote:
HA! I got it!
Hey- you're not the first one to get the ins&outs confused.
This is the reason I have my cables color coded- particularly on the Nord Modular
Audio files: 228
PostPosted: Mon Mar 13, 2006 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I had a NM1, I used to always confuse PC IN and PC OUT. It is not obvious what that means. I'm always confused anyhow, so the NM1 made me feel quite comfortable. Confused
GovernorSilver
PostPosted: Fri Mar 17, 2006 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
My money is on Micah discovering a bad MIDI cable after all.
Of course my opinion is colored by my own very recent experience. I learned that if you buy MIDI cables in pairs so that they are attached to each other, one of them can still go bad while the other one still works! Doh!
saturnineproductions
PostPosted: Sat Apr 29, 2006 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry to say. i'm having this very problem. i've just gotten my nord modular, installed everything i think/thought i needed and still the mac doesn't seem to recognize it.
i'm not a total tard, but i think i might need some help with this.
i'm running 10.4.6
nord modular nm1
i've got the midi ports connected to:
korg microkontrol (in)
electribe er-1 (out)
and the pc ports are connected to
m-audio 1x1 midisport.
please please please?
PostPosted: Sat Apr 29, 2006 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
The usual problem is to mix up which "pc" ports are in and out.. Very Happy
Flickr
PostPosted: Sat Apr 29, 2006 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
tried switching those. i got a lot of noise... i can only assume the noise is due to reversed cables.
still trying
PostPosted: Sat Apr 29, 2006 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm.. Question Shocked
This is weird. I dunno. I am using a G4 just for the editor app. I am not running any other midi stuff on it at all. I have never actually tried running he editor from the main DAW.
Flickr
