Using a P5 glove or other HID as MIDI controller?
Page 1 of 1 [5 Posts]
utenzil
PostPosted: Thu Apr 13, 2006 10:56 am    Post subject: Using a P5 glove or other HID as MIDI controller? Reply with quote  Mark this post and the followings unread
Hiya,
I use a P5 glove, joysticks and gamepads as MIDI controllers in conjunction with HID to MIDI mapping software and Ableton Live software. Anyone else doing this?
Utenzil
http://utenzil.com
PostPosted: Thu Apr 13, 2006 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please elaborate! I'm interested in this, especailly gamecontrollers, and am always looking for a better solution. What software are you using?
utenzil
PostPosted: Thu Apr 13, 2006 4:58 pm    Post subject: hid to midi Reply with quote  Mark this post and the followings unread
sure. Btw, I'm using Windows XP Home SP2 and Ableton Live.
The HID to MIDI conversion software I use is called "Rejoice". http://fireballtrailers.com/rejoice
I use this in conjunction with the loopbe midi yoke from http://nerds.de which is a very inexpensive license. (MIDI yoke as mentioned on the Rejoice site will work also, it's free, but more complex to set up).
There is similar software for Mac called junxion (i am less familiar with this, I'd suggest googling that) but I do not know if it will support P5.
Plogue Bidule http://plogue.com will also support HID to MIDI for joysticks as well as USB keypads. Plogue's P5 support is more limited than Rejoice, however.
Utenzil
http://utenzil.com
GovernorSilver
PostPosted: Fri Apr 14, 2006 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I have a P5 glove too, and messed around using it with Max/MSP.
I ran into an artist who uses P5s a lot more often than I do and he says he buys spare P5s wherever he can find them because each P5 he has had breaks down after a few months of use.
utenzil
PostPosted: Mon Apr 17, 2006 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that's probably a good idea-- I've been worried a little about the durability.
GovernorSilver, btw, a group of Ableton Live users (including myself) will be playing laptop in DC at the Black Cat 5/7, $5 cover.
Utenzil
http://utenzil.com
