Little problem with oscillator string
Page 1 of 1 [4 Posts]
nuts
PostPosted: Fri Oct 13, 2006 10:20 am    Post subject:  Little problem with oscillator string
Subject description: noob on G2
hi,
when i play this very simple >patch< the sound is "flanging" and i don't know how to stop it, what can i do please ?
Also i like to know what produce this effect , i really don't understand why and it is interesting in fact...if you control it.
Thanks Very Happy
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Oct 13, 2006 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
The string oscillator is a tuned delay with feedback, a short burst of noise is all that is required to make it produce a tone like a plucked string. If it gets a sustained oscillator signal as input, there will be interactions between the oscillator frequencies. New notes will sound different depending on what is still in the string oscillators buffer.
It is a nice effect.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Oct 15, 2006 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
the string osc is a wonderful fx processor Wink
/Dasz
nuts
PostPosted: Sun Oct 15, 2006 7:51 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you, i understand now.
But i set all the enveloppe's parameters of the signal in oscillator to zero to create only a little click but it continue to "flanging" ?
