Nm1 Spectral Oscillator
Page 1 of 1 [4 Posts]
3phase
G2 patch files: 141
PostPosted: Thu Jan 25, 2007 11:12 pm    Post subject: Nm1 Spectral Oscillator Reply with quote  Mark this post and the followings unread
The Nm1 Spectral Oscillator in a updated and callibrated model. Carefully tuned to match levels and some sonical characteristics of the original..
Still looses a tiny bit in the direct comparison but it is much closer than the ones i did before.
Probably as close you can get with reasonable module effort.
 Filesize:  42.72 KB
 Viewed:  10069 Time(s)
spectral2 model.pch2
 Filename:  spectral2 model.pch2
 Filesize:  1.87 KB
 Downloaded:  2064 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Jan 30, 2007 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Sven, this sounds quite cool. I don't have an nm1, so I'm not sure - is it supposed to go that loud when the shape is turned up? It seems to be quite a jump in volume...
3phase
G2 patch files: 141
PostPosted: Tue Jan 30, 2007 9:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes..thats the trick that makes the spectral osc so nice for sequenced sounds..its very articulated...this one sounds very close to the original...
I however still would prefer when clavia would just bring it back..
the shape osc is usefull aswell..very usefull...but the spectral osc is one of the best features of the nm1 and as you see ..its quite expensive to get close.. i even could do it closer ..the orginal spectral has a slightly smoother sweep thru the shape range But as this is done for the converter i had to keep the szise in mind...
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Thu Feb 01, 2007 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah sweet, cheers Smile
