Nord Lead 3 fuse problems in general?
Page 1 of 1 [5 Posts]
nowhanded
PostPosted: Sat Feb 03, 2007 7:37 pm    Post subject: Nord Lead 3 fuse problems in general? Reply with quote  Mark this post and the followings unread
my lead 3 is having problems and i think it might be the fuse. im not sure.
i was wondering if someone could give me the rating on the fuse in the board....for the u.s. model.
disrupt_the_imc
PostPosted: Mon Feb 05, 2007 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
What kind of problems are you having?
nowhanded
PostPosted: Tue Feb 06, 2007 1:01 am    Post subject: Reply with quote  Mark this post and the followings unread
it'll work fine for a few minutes then noise starts "behind" the patch. like an osc thats being modulated randomly and noisily....if that makes any sense. but you can still play the patch over the top of this noise. switch patches and the noise remains but you can play the new patch. the same time this started about half an octave of keys decided to stop responding.
i know this probably isnt a fuse related problem....im just wondering if a fuse related problem caused this.
disrupt_the_imc
PostPosted: Tue Feb 06, 2007 1:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I doubt a fuse would cause that. Once a fuse blows, your synth won't turn on. I don't own a Lead 3 but a 2X. The fuse in this one is some crazy porcelain fuse, like in a microwave. Now if you replaced that one, or the previous owner(if there was one) with a standard run of the mill fuse, than that could be your problem. If that's not the case, than get ahold of Clavia. Worse case scenario? Fuct motherboard. That's worse case.
I'm strictly assuming, the lead 3 has a porcelain fuse, somebody here can help 'ya with that. Since I don't own one.
rodv
PostPosted: Thu Nov 18, 2010 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi man, im experiencing the same problems, did you find any solution?
