Joined: Apr 03, 2004 Posts: 24422 Location: The Netherlands, Enschede
Audio files: 297
Posted: Fri Mar 23, 2007 8:06 pm Post subject:
Scott Stites wrote: | Always the surgeon after the patient's closed, eh? |
Amice,
All well but indeed that aorta is obstructed, and patient suffers from LFO bleed, and maybe from syncing osc syndrome, tinitus and bad hum as well. And no tranquilizers will help here, so something must be done !
The banana therapy could just be the right thing, thick wires. _________________ Jan
zonkout
Joined: Oct 12, 2006 Posts: 33 Location: ozztin, teggsitz
Posted: Tue Mar 27, 2007 7:23 am Post subject:
I'd like to thank you all again for your help with this.
I haven't eliminated the LFO bleed, BUT it is far more subtle now--barely audible once I have a few different patches running simultaneously. Before I couldn't run a percussive patch and play along on the keyboard because the percussion would modulate the oscillators in the keyboard patch. Now I can patch up a little drum beat and play along without the intrusion.
The solution turned out to be very simple: a shorter cable of higher gauge connecting the psu to the case. I also put the noisy modules closer to the power supply in the chain. The connecting cable seemed to be the real issue, though.
The next step will be hooking up my distro boards in parallel to completely eliminate the bleed.
Thanks to you guys I can now fully enjoy my modular! |
zipzap
Posted: Wed Mar 28, 2007 7:11 am Post subject:
just a thought, this may be complete nonsense:
isn´t it possible to run a critical module "inbetween" opamp buffers or gyrators?
i have used one transistor gyrators for critical amp circuits. on the neg and pos rails. mainly to get rid of hum and oszillation on the power rails (which seems to happen when you power a circuit with very little power needs from a 7812) is there no such thing for ground? like a opamp that buffers a 0v voltage as the ground of the module?
or would that make connecting to other modules impossible without a real ground connection? _________________ http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines |
Posted: Wed Mar 28, 2007 3:14 pm Post subject:
Sounds like a great idea. But I don't know if it's possible or not. Because the external connections are all referenced to ground, maybe there will always be contamination problems.  _________________ What makes a space ours, is what we put there, and what we do there. |
