astroid power-up!
astroid power-up!
Joined: Apr 03, 2004 Posts: 24423 Location: The Netherlands, Enschede
Audio files: 297
Posted: Sat Apr 14, 2007 12:29 pm Post subject:
Not sure sure what you want and/or expect ...
What could kill connected equipment is out of specs voltages on it's inputs. On old modulars gate inputs sometimes have restricted levels 0 .. 5 V, for other inputs a range from -10 to +10 V is usually safe. The kit has the tools to make sure of signal levels.
It's just that I wonder what it would add to a modular system .. in itself.
I see this as a (self) teaching tool, this might of course result in circuits of interest for a synth, and as such I can see use for hooking it up to a synth. I'd expect people to rebuild a found circuit into a more permanant module like thing to be incorporated in the synth then/afterwards.
This moght cost quite some money, but it looks like a useful tool to learn about electronics. It depends a bit on the quality of the instruction material that comes with it. _________________ Jan
astroid power-up!
Posted: Sat Apr 14, 2007 12:37 pm Post subject:
well, i'm looking for low-level stuff, like logic gates, flipflops, comparators basically all the small stuff that the g2 has. also, having low-level components seems just dead sexy.
i'm a tinkerer at heart, even though i know nothing about anything.
i'm not expecting some crazed sound generators, but more stuff where i can implement little weird kinks and stimulate my imagination.
and, some of these used kits tend to be cheaper, like waaaay cheaper. you might find a kit with 20 logic gates/6 flipflops/etc. for less than 50 bux. if they worked, it'd be a really easy way to put logic into a modular. _________________ Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Sat Apr 14, 2007 12:43 pm Post subject:
I used to had a big logic one with some other interesting stuff in it.
Like a comparator etc it was a ces ed-lab one. |
astroid power-up!
Posted: Sat Apr 14, 2007 12:44 pm Post subject:
so it worked with modular stuff pretty well? _________________ Astroid Power-Up!: "googleplex" available at:
Audio files: 297
Posted: Sat Apr 14, 2007 12:55 pm Post subject:
Ok, the 2nd link seemed to point to something more analog in nature.
With using logic circuits in a synth you have to take care not to blow the logic's inputs as well. this depends on the logic family used. CMOS circuits could be useful as they could have a supply voltage of 15 Vollt. You'd probably want some protection circuits to make sure that they never see less than zero or more than 15 V in their inputs. For other families the max voltage could be 5 V, not as practical for a modular system.
I looked at some of the logic kits, but could not find what family was used.
Are you sure you don't want to do some soldering yourself ? It wouldn't be too hard ... pick some interesting CMOS gates solder them on perf board together with some protection then add a bunch of of connectors and off you go. _________________ Jan
astroid power-up!
Posted: Sat Apr 14, 2007 1:02 pm Post subject:
well,
i would love to, but 1. i'm totally without any understanding of electricity and 2. i don't have a place to solder. i don't wanna do it in my small apartment, because our ventilation isnt up to snuff. _________________ Astroid Power-Up!: "googleplex" available at:
mono-poly
Posted: Sun Apr 15, 2007 7:13 pm Post subject:
The ED-Lab worked ok with my Serge. |
cebec
G2 patch files: 31
