ian-s
Audio files: 42
G2 patch files: 626
Posted: Sat May 26, 2007 10:35 pm Post subject:
sine to triangle converter |
Stumbled across something that might be useful.
I have been playing with the sin cos generator from the G2 building blocks. I found that you can make a good triangle wave by full wave rectifying the tops and bottoms of the sin and cos respectively, then summing the result. The triangle is at twice the frequency of the sine.
Feeding the sin and cos into a two input xor gate, a square wave is formed with a high period coinciding with the rising slope of the triangle.
This means the triangle can be converted to a sawtooth with the good old conditional inverter technique.
I thought that a hardware version of this would be quite simple, and be an ideal companion for something like the Mankato Filter. Letting it double as a regular oscillator with Triangle, Sawtooth, (PWM is easy) and a true sine suboctave.
Sorry in advance if this is common knowledge.
Description: |
Filesize: |
4.27 KB |
Viewed: |
10134 Time(s) |
Description: |
G2 patch should run in Demo |
 Download (listen) |
Filename: |
triSawFromSinCos.pch2 |
Filesize: |
1.52 KB |
Downloaded: |
1698 Time(s) |
yusynth
Posted: Sun May 27, 2007 12:55 am Post subject:
Well there are other ways to do so in analog electronics.
An example is to use a tri2sin converter that you insert in the feedback loop of an OPA. _________________ Yves |
zipzap
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
zipzap
Posted: Mon May 28, 2007 1:10 am Post subject:
but that won´t be twice the speed of the sine. Ok, if you keep the rest you would have switchable sine or tri subosc... But than we´re propably better of building a nother vco...
anyway, that´s frequenzy dependant, right?
With higher freq the amplitude will get smaller and smaller.
but i think i´ve got something, let me have a look... _________________ http://www.myspace.com/lorolocoacousticpop
music and transcribed jazz basslines |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Mon May 28, 2007 3:21 am Post subject:
Making a triangle from a sine is perhaps not so interesting. What I thought was neat was that a simple two input xor gate could be used to generate a square wave with exactly the right phase relationship to convert the triangle to a sawtooth. The sort of luxury you only get with a triangle core vco.
Seems it would only be a few dollars worth of parts to convert any quadrature sine source into a vco with a full set of waveforms. |
zipzap
Posted: Mon May 28, 2007 3:30 am Post subject:
I once modded a state variable filter to parform like a quadrature sine vco. It was still possible to apply input signals in vco mode (rather strong, diode limited resonance).
Wonder what your shapers would give me in that case... _________________ http://www.myspace.com/lorolocoacousticpop
ian-s
Audio files: 42
G2 patch files: 626
Posted: Mon May 28, 2007 3:39 am Post subject:
zipzap wrote: | Wonder what your shapers would give me in that case... |
That's spooky, I was just thinking the same thing. |
zipzap
