About 5/4 on the sequencer
Page 1 of 1 [3 Posts]
Tool
PostPosted: Fri Aug 03, 2007 5:06 am    Post subject: About 5/4 on the sequencer Reply with quote  Mark this post and the followings unread
Well I have this patch... is about 3 sequencer modules and the first one repeats x times and then jump to the second module which repeats x times and then jump to the third module and then the chain stop... I want to do this but with a 5/4 instead of a normal 4/4... Anyone can help me to do that?...
Thanks and sorry for my english
chain3_111.pch2
 Filename:  chain3_111.pch2
 Filesize:  2.54 KB
 Downloaded:  1703 Time(s)
chain3_111.pch2
 Filesize:  2.54 KB
 Downloaded:  1710 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Aug 03, 2007 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Your english is good.
The clock module is a little biased to the 4/4 people. Smile
See attached patch, exactly the same as yours but added a clock divider which allows selecting any beat from 1-16 to replace the Sync output.
Variation 2 sequencers are set for 3 bars of 5/4 so sequence length is 15.
chain3_5_4.pch2
 Filename:  chain3_5_4.pch2
 Filesize:  2.58 KB
 Downloaded:  1838 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Mon Aug 06, 2007 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't get this?
I thought 5/4 was 5 qtr beats a bar, e.g. pattern length must be 20 steps and not 30.
Sorry if I am being thick.
iP (Ross)
