 Forum index » Clavia Nord Modular » G2 Patches - Completed » Pad
Low DSP strings
Page 1 of 1 [3 Posts]
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Aug 13, 2007 3:53 pm    Post subject: Low DSP strings Reply with quote  Mark this post and the followings unread
Here is very low dsp/mem retro string pad.
It uses two pairs of sine oscillators with diode rectifiers. Summing the opposite full wave rectified halves gives a variable slope saw/triangle/ramp. The shape depends on the phase difference. Because the oscillators are detuned, the phase and therefore shape is constantly changing at the beat frequency. A keyboard morph on the fine tune evens out the variation in beating, and a chorus in the FX area blurs things into a 70's style string ensemble effect.
Might be useful if you need a string-like pad and are running low on DSP.
I think the basic idea should work on the NM classic so might be a good one for Micro owners.
cheepstrings.pch2
very low dsp <12.5%
 Filename:  cheepstrings.pch2
 Filesize:  1.5 KB
 Downloaded:  2247 Time(s)
Tim Kleinert
G2 patch files: 236
PostPosted: Tue Aug 14, 2007 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
This definetely has that "string-ensemble"-vibe. I like it. Thank you.
iPassenger
G2 patch files: 78
PostPosted: Thu Aug 16, 2007 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Great patch but i don't really understand it. Smile
iP (Ross)
