strms
Posted: Thu Aug 16, 2007 10:22 am Post subject:
I got a synth and drum machine Subject description: now how do I record them |
I finally got an Alesis Micron and a boss dr 202 drum machine....how am I supposed to record them.
I want to be able to directly record into my computer, my computer doesn't have any midi in/out.
I bought a Behinger MX400 4 channel mixer.....
I have a tascam 4 track portastudio
Am I supposed to record them with the midi out/thru or through the headphone output?
Totally confused with this.
Andrew |
strms
Posted: Thu Aug 16, 2007 3:29 pm Post subject:
I just ended up buying a midi to usb cable today, it will work. |
Posted: Thu Aug 16, 2007 4:20 pm Post subject:
MIDI does not do audio. It contains only the information that, for example, a musical score would have. MIDI was developed in the early 80's. Long before computers were doing anything near quality audio. |
ian-s
Audio files: 42
G2 patch files: 626
Posted: Thu Aug 16, 2007 4:24 pm Post subject:
jrstubs wrote: | I just ended up buying a midi to usb cable today, it will work. |
It will let you play the drum machine and synth from a midi sequencer on the PC.
To record the sound, you will need to take the L R outputs of the Drum machine and Micron to your mixer, then take the L R out of the mixer into the PC audio in.
What recording/sequencing software are you using? |
strms
Posted: Fri Aug 17, 2007 5:22 am Post subject:
audacity and fl studio |
strms
Posted: Fri Aug 17, 2007 7:26 am Post subject:
Quote: | To record the sound, you will need to take the L R outputs of the Drum machine and Micron to your mixer, then take the L R out of the mixer into the PC audio in.
I pretty much already did that....the mixer doesn't have l/r output or input, its 1/4" phone jacks I think.
www.myspace.com/awbproject - tester, thats the song I made with the line in on my computer. |
EdisonRex
Audio files: 172
Posted: Fri Aug 17, 2007 7:42 am Post subject:
jrstubs wrote: | Quote: | To record the sound, you will need to take the L R outputs of the Drum machine and Micron to your mixer, then take the L R out of the mixer into the PC audio in.
You might need to visit Radio Shack to get some adaptors. _________________ Garret: It's so retro.
strms
Posted: Fri Aug 17, 2007 9:33 am Post subject:
EdisonRex wrote: | jrstubs wrote: | Quote: | To record the sound, you will need to take the L R outputs of the Drum machine and Micron to your mixer, then take the L R out of the mixer into the PC audio in.
You might need to visit Radio Shack to get some adaptors. |
so you mean.... the l/r outputs have higher audio output quality? Those adapters are pretty cheap. |
EdisonRex
Audio files: 172
Posted: Fri Aug 17, 2007 9:45 am Post subject:
Let's put it this way.
The mixer takes the signals from your synthesizer and drum machine and allows to to mix, or combine, them, as well as position them in the stereo field (using the pan controls). Also allows you to colour the tone using the equalisation controls.
The output of the mixer is what you need to record. So you need to look at those outputs. Depending on the mixer, they could be RCA (phono) jacks, they could be 1/4" phone jacks, or they could be XLR balanced output jacks. In any case, they are all "line level", or of suitable amplitude (volume) to serve as input to your computer's sound card.
However the sound card probably uses 1/8" mini-phone jacks, and stereo to boot, so you'll need an adaptor. Radio Shack carries these, most computer stores would have them too, but usually they are mini-phono stereo to RCA, so you might need RCA to 1/4" phone jacks. Not knowing the mixer, I couldn't tell you for sure. _________________ Garret: It's so retro.
strms
Posted: Fri Aug 17, 2007 9:48 am Post subject:
I already have 2 1/8" to 1/8" cables, and two 1/8" - 1/4" adapters. So I can take the output from the mixer and plug it into the line in on my computer. I have that much figured out. When I recorded that "song" yesterday, the sound got somewhat distorted, I really don't know how or why. I'll figure it out don't worry I guess. |
EdisonRex
Audio files: 172
Posted: Mon Aug 20, 2007 1:46 pm Post subject:
jrstubs wrote: | I already have 2 1/8" to 1/8" cables, and two 1/8" - 1/4" adapters. So I can take the output from the mixer and plug it into the line in on my computer. I have that much figured out. When I recorded that "song" yesterday, the sound got somewhat distorted, I really don't know how or why. I'll figure it out don't worry I guess. |
Levels are too high. Turn down both the mixer output, but especially the computer input. Especially turn down the computer input. You will hear less noise if your sources are loud and your inputs are low. _________________ Garret: It's so retro.
strms
Posted: Mon Aug 20, 2007 2:23 pm Post subject:
O.K. |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Tue Aug 21, 2007 1:41 pm Post subject:
To be more specific... the audio interface has to convert the analog signal from the mixing board to digital. Digital audio has a fixed range of amplitude values it can handle. If the voltage coming in goes out of that range, the digital stream will be clipped to the minimum and maximum values.
The only way to fix it is to make sure the input signal to the computer is not too loud. Audio interfaces don't magically adjust the input volume for you.
Have you read any material on digital audio basics? A quick google search on "digital audio tutorial" turned up some useful documents.
I strongly recommend you check some of this out. Recording audio (analog or digital) requires some specialist knowledge... not too hard to learn but you should be prepared to put the time into it if you want to get good results.
James _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
dewdrop_world
