merceditas008
Posted: Sun Dec 23, 2007 5:32 pm Post subject:
configurating MIDI |
hi!
1st try with receveing MIDI, sorry..
im trying to receive some MIDI signal from my laptop using LOGIC through an M-AUDIO soundcard, but nothing seems to happen. I´m afraid something to do with the channel configuration of it...someone can help please?
thanks!!! |
seraph
Editor
Audio files: 33
merceditas008
Posted: Mon Dec 24, 2007 1:41 am Post subject:
im afraid i cannot...im in a quite isolated place for xmas with no macs around..
I remember using it once with a ROland and it worked, through channel 8..
Maybe its just a very simple thing im not doing right, complete beginner in MIDI implementation..
thx again |
seraph
Editor
Audio files: 33
Posted: Mon Dec 24, 2007 6:19 am Post subject:
is there a midi controller (a keyboard or something) in your setup? _________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
merceditas008
Posted: Mon Dec 24, 2007 8:24 am Post subject:
No,im using the G2 as synth and MIDI controller at the same time with logic, but i cannot record the sound and the MIDI sequence at the same time, so i wanna record 1st just the sequence of MIDI and then send it back through logic to the synth, so i can record the synth sound that time and this way all in perfect syncro..
i dont know if all this make any sense..  |
seraph
Editor
Audio files: 33
Posted: Mon Dec 24, 2007 1:11 pm Post subject:
the USB connection of the G2 is only used for the editor so in order to transfer midi data to the laptop you need a midi-usb interface and an audio interface to record audio from the G2 to the computer. is that clear? _________________ homepage - blog - forum - youtube
merceditas008
Posted: Mon Dec 24, 2007 6:28 pm Post subject:
jeje...yeah, thats clear..
I use an M_AUDIO soundcard for both things:
through MIDI cable, the keyboard of the G2 acts as the controller
through audio cable (output G2-input soundcard), i take the sound of the G2 into the comp
but then, when i change the midi cable,from MIDI OUT in the soundcard to MIDI IN in the G2 is where i dont get any connection...
klangumsetzer
Audio files: 36
Posted: Tue Dec 25, 2007 7:17 am Post subject:
so notes are recorded in logic but you can't play back notes from within logic on the g2?
hm, did you setup the g2 via logic's environment? is midi sent to the appropiate midi port? disable the input from within logic (track parameters) or physically disconnect g2 -> pc midi when playing back midi data to prevent midi loops.
hope this helps
eike
merceditas008
Posted: Wed Dec 26, 2007 1:50 am Post subject:
and how do i set up the G2 for logic environment??
im trying changing the channels and some oher things but nothing seems to work, neither in the MIDI settings of the LOGIC...it doesnt even appear the G2 itself recognized as a controller...it should?(i mean, the name of it...the keyboard for instance works when im using it to play the notes in the virtual KOMPAKT i use..)
thanks!! |
klangumsetzer
Audio files: 36
Posted: Fri Dec 28, 2007 2:00 am Post subject:
try this:
1) select a midi track in logic
2) in the track parameter window select the midi in port of your m-audio soundcard which is connected to the g2 midi out port.
3) again in the track paramter window set the midi out port to 'none'
you should be able to record midi data now.
best regards
eike
merceditas008
Posted: Fri Dec 28, 2007 3:00 am Post subject:
sorry, i think i didnt explain myself clearly..
I can record the midi notes that im playing with the keyboard of the G2 in logic. BUt i cannot send later those same MIDI notes to the G2 back so they can "play" the patch of the G2 i select..
thx again! |
klangumsetzer
Audio files: 36
Posted: Sat Dec 29, 2007 12:23 pm Post subject:
ok then:
1) set input to none
2) in the track parameter box select the appropiate midi out port (not the one meant for the editor)
3) you should see the midi notes being sent in the transport bar when you hit play
best regards
eike
