Nord lead factory reset
Page 1 of 1 [4 Posts]
schizoping
PostPosted: Tue Jan 08, 2008 1:02 pm    Post subject: Nord lead factory reset Reply with quote  Mark this post and the followings unread
Hi all, this is my first post here!
I've bought a second hand nord lead 2x, with valid warranty 'till october 2008.
Some month ago, it started to seem broken: the pitch-stick and the modulation weel sometimes didn't work...
I was bypassing the problem "rebooting" the NL ( turn off and then turn on).
Now the wheel and the stick don't work at all!
Could it be a software problem? I think so...
And if it is a software problem how can i reset the NL to the initial settings?
Audio files: 299
PostPosted: Tue Jan 08, 2008 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome schizoping
software problem, don't think so ... could be a loose connector or something ... two devices giving up at the same time is not likely either ... I'd open it and check the connector for the wheel and stick, maybe pull and replug it.
schizoping
PostPosted: Wed Jan 09, 2008 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
But seem strange to me that an hardware problem can be solved turning off the synth... (not even more anyway)
I've tried to open it but i can't completely remove the red-metal-part. (i was in a hurry and afraid for the warranty Laughing )
Watching through the aperture it seem to be all ok.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Wed Jan 09, 2008 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
There are 4 screws at the back and two at each side (Leave the two with the washers) AND there is one at the bottum, right underneath the Wheel.
Wout
