sonictransportsystem
Posted: Sat Feb 02, 2008 6:05 am Post subject:
Evolver gets crazy!! |
Hi to everyone!
Sometimes my dektop evolver, when is playing sequencer and tweaking the knobs starts to change the values alone, with the speed of seconds on a clock, and the sequencer led starts blinking and i need to turn off the synth and then turn on again....its really strange! So if you have any idea please help me.
P.S. that happens with midi clock internal and external.
Thanks a lot
Pedro Dias
www.myspace.com/sonictransportsystem |
earsmack
Posted: Sun Feb 03, 2008 3:58 pm Post subject:
I've seen a few of my synths (not my Evolver but I'm just passing this on) crash when multiple devices were sending MIDI clock. Regardless if the crashing machines were trying to follow the clock or not, it seemed as though too many clocks being sent was overflowing their buffers and causing them to crash. Just a thought - yank the MIDI cables and see if it still happens. |
Posted: Mon Feb 04, 2008 2:02 am Post subject:
zbq wrote: | I've seen a few of my synths (not my Evolver but I'm just passing this on) crash when multiple devices were sending MIDI clock. Regardless if the crashing machines were trying to follow the clock or not, it seemed as though too many clocks being sent was overflowing their buffers and causing them to crash. Just a thought - yank the MIDI cables and see if it still happens. |
Many thanks for the advice, but has i said the problem happens receiving midi clock and not receiving midi clock, so happens too with the machine playing alone, the midi in cable is connected but no midi clock cause my other machines are turned off....  |
earsmack
Posted: Mon Feb 04, 2008 5:13 pm Post subject:
sonictransportsystem wrote: | zbq wrote: | I've seen a few of my synths (not my Evolver but I'm just passing this on) crash when multiple devices were sending MIDI clock. Regardless if the crashing machines were trying to follow the clock or not, it seemed as though too many clocks being sent was overflowing their buffers and causing them to crash. Just a thought - yank the MIDI cables and see if it still happens. |
Ok - I didn't think you mentioned the other machines were off. I would suggest emailing Dave Smith. Good luck figuring it out. |
Posted: Mon Feb 04, 2008 6:42 pm Post subject:
zbq wrote: | sonictransportsystem wrote: | zbq wrote: | I've seen a few of my synths (not my Evolver but I'm just passing this on) crash when multiple devices were sending MIDI clock. Regardless if the crashing machines were trying to follow the clock or not, it seemed as though too many clocks being sent was overflowing their buffers and causing them to crash. Just a thought - yank the MIDI cables and see if it still happens. |
I already emailed Dave Smith, and they are going to help me!
Thanks a lot |
Posted: Tue Feb 05, 2008 12:14 pm Post subject:
But please, post back what ever the solution happens to be! (I have a Desktop evolver, also). |
Posted: Tue Feb 05, 2008 12:23 pm Post subject:
jksuperstar wrote: | But please, post back what ever the solution happens to be! (I have a Desktop evolver, also). |
Ok....but you dont have the same problem? |
Posted: Tue Feb 05, 2008 11:59 pm Post subject:
No, the only time things change "by themselves" is when I assign a sequencer to that value. So I'm not sure what problem you're having. Do you see it with a certain patch? Or with any patch? What version of the firmware are you using? |
Posted: Fri Feb 08, 2008 4:11 pm Post subject:
jksuperstar wrote: | No, the only time things change "by themselves" is when I assign a sequencer to that value. So I'm not sure what problem you're having. Do you see it with a certain patch? Or with any patch? What version of the firmware are you using? |
I have version 3 and happens with any patch. It seems that what changes alone is only the program numbers, not the values of the knobs im tweaking, either i was not tweaking this time just pushing buttons of the programming matrix, this time i didnt reboot the Evolver, just pushing all buttons to see if he stop without rebooting, and then he stops im sure that was not cause i push all the buttons to see if he stop, it seems that he stops when finish counting the 128 programs of the 4 banks. It was this that was happening, but cause i was tweaking the same time i didnt understand that what changes is program numbers and not the data of the last knob i tweak....next time im going try to see even more clearly whats happening!
Cheers |
Posted: Fri Feb 08, 2008 4:14 pm Post subject:
I have been working all day with the evolver and is working perfect....maybe cause yesterday i let him count all the programs of the 4 banks he decide to stop making strange things...Oh this machines put me crazy!!  |
Posted: Wed Feb 20, 2008 4:05 pm Post subject:
It seems in that i have been making bulk dump without knowing.... thats why the sequencer start stop led flashes and the programs start to change alone. until the last one of the 4 banks!
If is that cubase didnt receive nothing...that i know.
Cheers |
