Nord Lead 3 beginner needs your help
Page 1 of 1 [4 Posts]
Brakeboard
PostPosted: Mon Feb 25, 2008 6:38 pm    Post subject: Nord Lead 3 beginner needs your help Reply with quote  Mark this post and the followings unread
I've just bought a second hand Lead 3 on ebay....and i just don't seem to be able to get a sound out of it..
Though I connected it to Protools and was able to record a midi signal and then listen to the sound when played back out its headphone jack
But I just can't seem to get a direct sound from any of the outputs?
I hope i've just missed something and it's not fuct.
Hope you can help
earsmack
PostPosted: Tue Feb 26, 2008 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Make sure LOCAL CONTROL (of the keyboard) is turned ON. If this is off then playing the keyboard will not make the instrument sound. You can check the manual for specifics on how to do this. The manual is also available online if you need a reference http://clavia.com/main.asp?tm=Support&clsm=Downloads
Hope this helps...
Brakeboard
PostPosted: Tue Feb 26, 2008 6:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yay... thanks! Now working.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Feb 26, 2008 11:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers and welcome Brakeboard
Wout
