Random-function troubleshooting
Page 1 of 1 [6 Posts]
Pehr
PostPosted: Wed Mar 05, 2008 3:36 am    Post subject: Random-function troubleshooting Reply with quote  Mark this post and the followings unread
I've just put in a fresh LM358 for the random-comparator (I didn't have on before) and I've started playing around with the random input ets.
Of course it is behaving a bit odd... Rolling Eyes
The random level pot does not seem to work at all.
The random reference seems to work in a very small interval in teh lower end of the pot.
In other words, a change of 1mm means comparator always on or off...
If I'm really lucke I can get a random sequence...
What could be wrong? I've replaced the 100 k pots with 50k ones but no diff... Crying or Very sad
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Scott Stites
Audio files: 96
PostPosted: Wed Mar 05, 2008 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Pehr,
What are you using as a random input? IE, that sounds like what you'll get if there is no signal applied to the random input or the random signal isn't making it from the input to the LM358.
Cheerio,
Scott
My Site
Pehr
PostPosted: Wed Mar 05, 2008 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm, good point. I havent tested if the signal gets through yet.
I've tried:
White noise
Pink noise
Gate 3 output
sine wave from a VCO
sine from LFO
Saw fromLFO
All with the same result, so I think I'll see if I get a signal at all.
brgds
- Pehr
YouTube channel
flickr photostream
Scott Stites
Audio files: 96
PostPosted: Thu Mar 06, 2008 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Righto - the signal should go to the anode of D4, then through D4 to pin 3 of U8 (the LM358). So, the signal has to be a bit higher than 0.6V or so to register, which I imagine the signals you describe more than acquire.
R94 (100K) connects between Pin 3 of U8 and ground, which provides the input impedance required for the the thing to work. The diode just keeps negative voltages from coming through.
Pin 2 of U8 should reflect the reference voltage as dialed up by your reference pot - I think that's fine, judging by the fact your LED comes on at the extreme setting, but it doesn't hurt to check. Usually. Laughing
Let me know what you find, Pehr.
Scott
My Site
Pehr
PostPosted: Thu Mar 13, 2008 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything seems to be in order... all components are connected correctly.
Next step is to do some measurements of voltages at some points.
YouTube channel
flickr photostream
Pehr
PostPosted: Thu Mar 20, 2008 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything seems to be working fine. The comparator works properly.
I guess it depends on the signal I have fed into the random input. Smile
YouTube channel
flickr photostream
