Vocoder morph assign problem
Page 1 of 1 [3 Posts]
torsig1967
PostPosted: Fri Aug 22, 2008 3:11 pm    Post subject: Vocoder morph assign problem
Subject description: Possible bug, or I'm doing it wrong...
I've been trying to make morph assignments to the vocoder bands.
Seems like there might be a bug here, don't know if it's in the editor. I'm using the OS X beta editor on a Intel Mac.
A) Right clicking: Morph option is greyed out.
B) Alt-clicking: I get an error message but the assignment is made (range can also be edited on the NM1 panel so it seems alright).
But when I assign the morph-group to a knob and turns it. seems like the assignments doesn't work. Often I also get "out of memory" when I reload the patch and the editor is up and running.
Anyone else have these problems?
Maybe it works in the Windows editor?
Audio files: 297
PostPosted: Fri Aug 22, 2008 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Under Windows I can assign morphs to the vocoder bands and a knob to the morph knob without any errors, but when I move the morph knob (either from the front panel or from within the editor) nothing happens to the vocoder bands, so morphing just doesn't work there for me either.
Edit: and when I store the patch into the NM and recall it later I get the memory error as well ...
torsig1967
PostPosted: Sat Aug 23, 2008 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that info. Seems like morphing of the vocoder-bands isn't implemented properly then.
