TL074 vs. OPA2134
Page 1 of 1 [4 Posts]
whomper
PostPosted: Thu Aug 28, 2008 3:14 am    Post subject: TL074 vs. OPA2134 Reply with quote  Mark this post and the followings unread
I have recently been pondering whether I should invest in purchasing the more expensive OPA2134 when in need for a TL072.
is it a better option? Does it provide a better sound quality than the TL-72?
It sure costs more, about 6-7 times more, but then again I am after cleaner sound.
Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de
StephenGiles
PostPosted: Thu Aug 28, 2008 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
No, save your money for a bomb shelter - the Russians are coming!!
Seriously, average ears could not tell the difference.
Ricko
Audio files: 27
PostPosted: Thu Aug 28, 2008 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
It probably depends on where goes in the food chain.
High quality audio op-amps in the CV chain are probably wasted. And if you put them early in the audio chain but follow them with ordinary op-amps, their clarity may be wasted too.
(Similarly, distortion on a single VCO might not be very easy to hear, but distortion when you have multiple VCOs mixed together is very easy to hear: maybe that is an effect you want, but again to reduce it you would again probably put the high-quality op-amps late in the chain.)
That is my theory anyway.
Rick Jelliffe
frijitz
Audio files: 54
PostPosted: Thu Aug 28, 2008 8:01 am    Post subject: Re: TL074 vs. OPA2134 Reply with quote  Mark this post and the followings unread
The OPA134/2134 have much lower leakage and offset than the TL071/072. I use them extensively in my oscillator and filter designs to improve tracking, temperature stability and range.
Ian
