micro and sync in ableton live
Page 1 of 1 [3 Posts]
thoffir
PostPosted: Sun Oct 26, 2008 2:19 am    Post subject: micro and sync in ableton live Reply with quote  Mark this post and the followings unread
i'm using live and micro in my setup. is there posibility that each time if choose patch that uses sequencer it will play in sync with live clock (and if possible metronome)
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Oct 26, 2008 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome thoffir
If I understand you well you can use the MidiGlobal module (In-group) to use the Ableton Live clock as source in the Patch. Maybe you'll have to us a LogicDevider.
If my memory serves me well (other computer) sync (e.g. whole bar, etc) is in the Synth Settings.
Wout
thoffir
PostPosted: Thu Nov 06, 2008 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
right, it is midiglobal with clock divider set to 6. noodles works great now with external clock (tried it with ableton live and kaoss pad 3).
