Power supplies
Page 1 of 1 [2 Posts]
Dragon's Lair
PostPosted: Fri Nov 21, 2008 1:05 am    Post subject: Power supplies Reply with quote  Mark this post and the followings unread
These are "OOPS" power supplies, they where originally supposed to be adjustable, but due to a brain fart during the design stage, I used the wrong pin out for the voltage regulators, so they can only use fixed regulators. Supplies have +/- 12v or 15v and +5v outputs, all inputs/outputs have .250 spade and through hole connections. Supplies do not come with the transformer, they require a 2 amp 24vct transformer. Boards are 3"x4"
The version with the smaller heatsinks is good for about 300ma per rail, and the larger heatsinks can handle about 600 ma per rail (300 on the +5v).
I only have 10 of these, once they are gone, that's it.
300ma version assembled and tested $40 / kit $25
600ma version assembled and tested $45 / kit $30
Board only $10
Prices are in US dollars
Specify if you want 12v or 15v
 Filesize:  107.01 KB
 Viewed:  276 Time(s)
crazeydazey
PostPosted: Fri Nov 21, 2008 2:02 am    Post subject: Reply with quote  Mark this post and the followings unread
any idea what that is in £s & P&P to england??
I would like a fully assembled and tested 15v 600ma version
