kxspxr
JovianPyx
Audio files: 224
Posted: Sat Jan 31, 2009 9:19 am Post subject:
My own guess as someone who has used 555s in analog synth circuits is "yes".
My suggestion is this: The circuit is simple enough to breadboard on solderless breadboard or stripboard or vector board or whatever you use.
Just try it and see.
One thing I would do - use a 7555 timer, not a 555. Pinout is identical, but the device is CMOS and won't nail your power supply with a huge current spike each time it resets as a bipolar 555 timer will. This spike is the source of the VCOs in a FatMan wanting to lock together (soft synch) when the VCO pitches are close together. I've used part number ICM7555. _________________ FPGA, dsPIC and Fatman Synth Stuff
kxspxr
Posted: Sun Feb 01, 2009 5:05 am Post subject:
ScottG wrote: |
One thing I would do - use a 7555 timer, not a 555. Pinout is identical, but the device is CMOS and won't nail your power supply with a huge current spike each time it resets as a bipolar 555 timer will. This spike is the source of the VCOs in a FatMan wanting to lock together (soft synch) when the VCO pitches are close together. I've used part number ICM7555. |
I will build the original circuit first, then my new version with an opamp and a IMC7556 -got a few of them lying around. I can use the remaining 555 for the LFO. Thanks for the help and advice! If anyone's interested, I can upload the layout for (both the original and my own opamp version) vero once I've verified it.
-Kasper _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
kxspxr
Posted: Mon Feb 02, 2009 10:30 am Post subject:
The 555 Modifier sounds great with the LM386. - so I built the PWM Fuzz from the Armageddon too. Sounds awesome! Two nice and easy builds both with their own (very) unique fuzz sound!
