<on air> Modulator ESP Adventures In Sound
VCF tracking: no Tempcos?
Page 1 of 1 [9 Posts]
Jaba
PostPosted: Thu Mar 05, 2009 7:04 am    Post subject: VCF tracking: no Tempcos? Reply with quote  Mark this post and the followings unread
Hello,
I want to build some of the Yusynth filters (actually all of them), but now I notice that none of your those filters has tempcos; do they manage to track correctly when oscillating ? how is it ?
should I want to add tempcos, would you please give details about them, such as specific value, where to put it in the schematic, ... ?
thank you
Paolo
Question
yusynth
PostPosted: Thu Mar 05, 2009 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nearly no VCF (Moog, ArP, EMS...) have tempcos in them.
Yves
Jaba
PostPosted: Fri Mar 06, 2009 4:02 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for your answer, but this sounds new to me
I am no expert, but all the schematics I have from ARP VCFs (4012, 4023, 4034, 4035, 4072, 4075) use a 1K87 3% 3500ppm Tempco resistor, and most transistor ladder based filters I have seen use a 1K Tempco 3000ppm, even the EFM VCF2f had it
maybe you just don't care about temperature compensation, or you found another way to make the tracking good enough, ... ?
but my point is: if I build your filters (trans. ladder and ARP4072) and make them oscillate, will I be able to play them in tune over at least three octaves ? (as if they were VCOs)
and if the answer is yes, then I would like to learn how you achieved it, if you would share your design criteria
yusynth
PostPosted: Fri Mar 06, 2009 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You are confusing goodness of tracking and temperature stability.
The tempco just compensate for frequency drift when ambient temperature is changing. The goodness of tracking over a given number of octaves depends mainly on the tracking of Icb versus Vbe of the transistor(s) involved in the exponential converter.
Therefore VCF in oscillation can achieved a good V/Oct over many octaves without having tempcos.
Concerning the various yusynth VCF : the moog and ARP clones track well over at least 5 octaves, the Steiner tracks well over three/four octaves and the diode EMS only tracks well over two/three octaves.
Now if you wish to use a tempco , then use a 1.8K 3000ppm PTC resistor, in the Moog clone substitute the tempco to R11 and in the ARP 4072 use a 1K tempco and substitute it to R46.
Yves
Jaba
PostPosted: Fri Mar 06, 2009 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
great!
thank you a lot, this makes me very happy
No more excuses now, I'll have to build them all.
I'll order the kits from Bridechamber for diode ladderVCF, MiniMoog VCF and ARP4072 VCF, and buy 3096 and other components for a Steiner VCF
Any plan to do more ARP clones, such as the 4023 and 4034/4035 filters, or the Odysseys VCOs ?
thank you
PaoloV
yusynth
PostPosted: Fri Mar 06, 2009 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Have fun then Wink
I have no plan of making more ARP clones, I am really satisfied with the ARP4072 and my yusynth VCOs, I am not interested in making ARP VCOs.
But one must never say "never" Wink
Yves
numbertalk
PostPosted: Fri Mar 06, 2009 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
You might find this interesting - http://electro-music.com/forum/topic-28604.html - you'd have to etch your own board but I've built this circuit and it's great!
Jaba
PostPosted: Mon Mar 09, 2009 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, very interesting
thank you numbertalk, and thank you yusynth
btw, which circuit did you build, numbertalk ? is it the dual ODY osc/ringmod ? it is already on my "to do" list
numbertalk
PostPosted: Mon Mar 09, 2009 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yep, that's the one.
