Lost Terrain - Serge Modular Explorations
Page 1 of 1 [4 Posts]
Carbon111
PostPosted: Sat Mar 21, 2009 4:10 pm    Post subject: Lost Terrain - Serge Modular Explorations Reply with quote  Mark this post and the followings unread
Originally this was going to be a distributed CD but I've decided to release it free on the web as MP3s as well as a lossless FLAC version: http://carbon111.com/lost_terrain.html
Lost Terrain contains three audio journeys powered by the wonderful Serge Modular Synthesizer. These pieces are composed from self-generating modular synthesizer patches with a little manually-played synth added for good measure here and there. These songs are free for personal enjoyment but are not licensed for commercial use.
Posted Image, might have been reduced in size. Click Image to view fullscreen.Posted Image, might have been reduced in size. Click Image to view fullscreen.Posted Image, might have been reduced in size. Click Image to view fullscreen.
Carbon111
PostPosted: Tue Mar 24, 2009 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
An overview of the elements of the pieces in Lost Terrain:
Artic-11/25
The real presentation piece in this album is Artic-11/25 as it's the most complex structurally. As an exercise, It was made with only the Serge "Creature" and "Gator" M-odules. Going into it I thought it was going to be very minimal with such a constrained palette but I was able to get a much wider selection of timbres and rhythmic motifs than I could have ever hoped.
The combination of the pulse divider and Boolean function blocks on the Gator allowed for lots of rhythmic variety even though derived from a simple pulse train - and having odd divisions as well as even ones allowed for some unexpected poly rhythms.
The Creature was the workhorse for sound generation in this pairing and I got many of the "bed" sounds, including the initial, and repeated, "rumbling drone with sonar ping" motif from this simple patch:
That was just a jumping-off point though - I added a lot of modulation from the Gator to that initial config to get those timbres.
The VCFQ turned out to be a fantastic sound source as well as being a workhorse multimode filter. The Trig input on that function block is a godsend for percussion of all types.
In Artic-11/25 there are maybe six tracks of Creature/Gator laid down.
Cenote-88
In Cenote-88, formally known as "Stumblegum" before its reworking, the Serge was used simply as a "rhythm track" accompaniment to improvised lines from an electric piano. In this piece the Serge was not multi-tracked, instead, the entire percussive section was generated from this single patch below which was tweaked with its pots through the duration of the piece to provide timbral and rhythmic changes:
Forest Area-9b
Forest Area-9b, though simpler in form both timbrally and structure-wise, used the most number of Serge function blocks. Patching on this one was much more straightforward. The melodic line that slowly builds through this piece begins as a random selection of voltages that becomes increasingly less random until about eight minutes in when the TKB is switched out of random mode and the melody becomes a repeating one.
Random pulses were used for the bird sounds and weird slow transients in the background.
A lot of long attacks on the timbres in this piece give it a weird "backwards" feel though no tracks were reversed.
andrewF
PostPosted: Mon Apr 06, 2009 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
love artic 11/25
well done thumb up
Carbon111
PostPosted: Wed Apr 08, 2009 10:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Very Happy
My album "Touch" is all generative modular music as well.
