-VCO-
Posted: Fri Mar 27, 2009 3:48 pm Post subject:
Synthacon feedthrough |
hiya people,
just finished one of my CGS pcbs (woohoo, my first day with my weller since...i can't even remember when! since i started working full time with electronics i've got very little time to build stuff. ironic really...), a cgs35 synthacon vcf. i still have to do some minor adjustments, such as the frequency range and the regular stuff. i did notice that the resonance pot's wiring on the pic on the page was reversed (or i was tired). anyhoo, simple to fix.
HOWEVER, when I hooked it up it seems I get quite a lot of feedthru - i can clearly hear the unfiltered signal in the background, especially when the freq pot is at zero. did i mess up or is there some kind of adjustment you can make? i did change the 2N2907 for a 2N5401 since i can get those through my job, but not the 2N2907. please help, i'd love to have a perfectly working module!
cheers |
andrewF
Posted: Fri Mar 27, 2009 7:36 pm Post subject:
You may be right suspecting the 2N5401
I didn't look at the specs too closely, but it seems to be spec'd for lower voltages and currents than the 2N2907.
Assuming all else is correct, it would be a good starting point to swap in another PNP tranny. |
-VCO-
Posted: Sat Mar 28, 2009 4:11 am Post subject:
Hmm, the maximum ratings for the voltages are much higher on the 2n5401 than the 2n2907, however the collector current (Ic) is half the 2n2907's. Maybe that's what causing trouble. Perhaps a BC327 could work? Its Ic value (collector current) is at 0.8A instead of the 2N2907's 0.6A, but all other values are quite similar. I don't want to order just a single transistor from the web with all the shipping and all that, it's just so much trouble for one little component. I can get all the other components through my work.
Are there perhaps any other transistors I could use in the 2N2907's place? |
andrewF
Posted: Sat Mar 28, 2009 7:01 am Post subject:
I didn't mean the max ratings, these circuits get nowhere near such levels - more the off and on characteristics.
my Steiners have A1015 PNPs, so other transistors can be substituted. |
