can't unnasign morph
Page 1 of 1 [3 Posts]
gentlclockdivider
PostPosted: Mon Apr 13, 2009 7:48 pm    Post subject: can't unnasign morph Reply with quote  Mark this post and the followings unread
HI everybody
Wonderfull forum this is ..especially for the nord modular users..so here goes
I have a problem with the deassigning from a morph group of certain pushknobs .
For example I assign different gate buttons of a ' gate time sequencer ' to a morph group...but it seems that the morphing doesnt always work ...what's even worse ...When I plug the gate signal cable to the row above the morphed line ( where no steps are selected ), it still pits out the old values of the morphed group ...whike there is no gate signal output
...I can't even unassign ( ther is no right mouse button menu for unnasging morphs ) and then get the messagge..morph error when reloading
So Has anyyone sucesfully morphed the gate trigger buttons ...?
I uploaded a simple trigger ex. , you'll probably get the morph error message , but can ayone confirm this and try to assign gate triggers to a morphgroup and succesfully morph between gate and no gate ..
THanks
gatetriggerbug.pch
morph gate trigger bug
 Filename:  gatetriggerbug.pch
 Filesize:  1.67 KB
 Downloaded:  271 Time(s)
gentlclockdivider
PostPosted: Mon Apr 13, 2009 8:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
NOrmally you can't assign morph to stepgate buttons withe the right mouse button ,the same goes for filter type .Instead I use Ctrl .click ...that way I can morph filter types ...but after the error occurs ...
TRy clicking on the filter types while holding control ...assings a morph group ...now reload the patch
Maybe someone knows a list of all the nord modular bugs ...cause I think I'm gonna encounter lots of them ( considering this is an 10 year old piece of technology )
morpherror.pch
 Filename:  morpherror.pch
 Filesize:  1.21 KB
 Downloaded:  272 Time(s)
gentlclockdivider
PostPosted: Tue Apr 14, 2009 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
o.k.
Has allready been mentioned in the past
http://74.125.77.132/search?q=cache:zzkH7UyvhXcJ:electro-music.com/radio/forum/post-112456.html%26highlight%3D+morph+assignment+problem+nord+modular&cd=3&hl=nl&ct=clnk&gl=be&client=firefox-a
