Bodega
Posted: Tue Jul 07, 2009 5:33 pm Post subject:
Sequential Switch and general sequencer confusion.... |
Hi all!
I was going to make a project where I'd have an 8-step sequencer and each step would have a simple octave control, the design for which I've already picked out.
That leads me to believe that what I need is something that generates a cv, selects between 8 send/returns and then routes that to one master output. In other words, a fairly standard sequencer (from what I understand a sequencer to be, anyways).
From a look at the Sequential Switch page it appears that it can choose between 8 inputs but not 8 outputs. Am I right in thinking the Switch is not what I need, or is there a way to set it up that would work in my setup?
thanks lots!
Matthew |
Bodega
Posted: Wed Jul 15, 2009 10:28 am Post subject:
Nobody?
I guess it is a bit of a newbieish question.... |
Joined: Apr 03, 2004 Posts: 24432 Location: The Netherlands, Enschede
Audio files: 297
Posted: Wed Jul 15, 2009 10:35 am Post subject:
Bodega wrote: | Nobody?
Maybe, but I just was not sure what you meant ... a sequencer basically would be an n-> 1 switch where some trickery cycles through the n switch postions, sequentuially usually, but not necessarily.
When the switch would be an analog switch it would not matter what side to label as input(s) or output(s) (so it could be seen as either 1->n or n->1).
Do you have a link to some circuit you have in mind? _________________ Jan
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Posted: Wed Jul 22, 2009 5:51 am Post subject:
Hi Bodega,
Not sure if this is helpful, but I built a sequencer using the CGS 07 boards.
This has the individual pulse outputs for each step going to a 1 pole 8 way rotary switch, meaning you can send each steps pulse to one of 8 outputs.
If you put a pot wired as a voltage divider before each switch, you could change the voltage going to each switch (only lower though I suppose).
I guess it would be easy to apply each of these 8 outputs to 'thingamajig (octave thing)', and then sum them all together after 'thingamajig (octave thing)'.
Not sure if this is what you had in mind though!
Charlie |
Bodega
Posted: Thu Jul 23, 2009 6:08 am Post subject:
Thanks for the replies, guys.
I'd like to use this circuit to adjust the pitch of each of the 8 steps:
http://electro-music.com/forum/post-251404.html&highlight=#251404
So it would be N>1 (i.e. the switch cycles through the 8 steps, which goes to a single out)
Quote: | When the switch would be an analog switch it would not matter what side to label as input(s) or output(s) (so it could be seen as either 1->n or n->1). |
What's confusing me is this, from the CGS site:
Quote: | It can route one of eight signals to its output, but not the other way around. |
Edit: I'm guessing I would put my 8 octave switches (as in the link above) in the 8 inputs in the lower right of this pic?
Maybe if I had it in front of me it would all make sense.  Last edited by Bodega on Thu Jul 23, 2009 9:34 am; edited 1 time in total |
fluxmonkey
Posted: Thu Jul 23, 2009 7:16 am Post subject:
i believe you make 8 simple voltage dividers: 8 pots, ground all the left lugs, positive voltage to all the right lugs, each wiper going to on of the 8 inputs. so as the sequential switch cycles thru the 8 inputs, it will output whatever voltage it sees from each pot/divider, in sequence.
b _________________ www.fluxmonkey.com |
Bodega
Posted: Thu Jul 23, 2009 9:40 am Post subject:
Right. I just corrected my previous post.
Obviously I'd need 8 of the octave switches and not just one.
So it looks like the SS would indeed work for what I need.
And just for the record - I know controlling a sequencer's output with just octave switches is a little boring, but I'm doing this for an art installation and I want something maximally simple. |
Bodega
Posted: Thu Nov 19, 2009 3:16 pm Post subject:
Now that I've got it in front of me, I'm wondering:
1) what are the 4 holes that are just in front of the power connector, by where -0.6v is written? They look like posts for heat sinks, but I'm sure that's not why they're there. There doesn't seem to be anything in the parts list that corresponds with those kind of holes.
2) Are the arrows after the LEDs just to REALLY make sure you know which direction they are going, or do they indicate something else?
3) Finally, just to save me a trip around town: the 10n cap by the power connector - can that be substituted with another value? I don't happen to have any 10n/.01uF caps on hand. I see that it's in the path of the Reset In, but I'm not sure how crucial that value is.
Any thoughts would be much appreciated...
Matthew |
andrewF
Posted: Thu Nov 19, 2009 4:34 pm Post subject:
Bodega wrote: |
1. I asked Ken about this once, the holes and all the copper are for heat dissipation, same reason there are two 2k2 resistors in parallel. This section of the PCB is getting -0.6V from -15V so there is some heat generated.
2. not sure, the leds are essential for the outputs to work. A regular diode would be okay too if you don't like blinkenlights. Though the SeqSwitch has a great light show, think Kit on dexies.
3. I am sure you could get away with different value, tho as close as possible, say 12n. You could also put two caps in parallel or in series to get the required value. If it doesn't work, you will have to do manual reset (press the button) until the next shopping trip |
neandrewthal
Posted: Thu Nov 19, 2009 8:07 pm Post subject:
andrewF wrote: | if you don't like blinkenlights. |
Haha, good one I pity the foo who don't like blinkenlights _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Bodega
Posted: Fri Nov 20, 2009 6:47 am Post subject:
Oh, no diodes for me - I do like the blinknenlights!
Bodega
Posted: Wed Jul 21, 2010 7:17 pm Post subject:
Hi again, collective EM group mind,
Finally decided I'd better get this thing working property. It cycles fine, and switches direction fine, but I can't seem to get it to reset. So it goes 1-8 or 8-1 but I can't seem to dial up shorter sequences. It seems that P1-8 all put out a voltage in the +5v neighbourhood.
If I connect, say, P4 directly to RST OR RSS, that should reset every cycle on the 4th step, right? Mine doesn't seem to do that.
Incidentally, I've been assuming that the RST is looking for a +5v Gate or Trigger, and the vertical line on the schem above between RSE and +15v means a momentary switch. If either of those aren't the case, it might explain some stuff.
Any help would be greatly appreciated! I've been looking at this thing for months without having the wherewithal to get it working....
Matthew |
andrewF
Posted: Thu Jul 22, 2010 6:49 pm Post subject:
Quote: | Hi again, collective EM group mind, |
<Deep> Hello Matthew </Deep>
Quote: |
So it goes 1-8 or 8-1 but I can't seem to dial up shorter sequences. It seems that P1-8 all put out a voltage in the +5v neighbourhood. |
The ouput voltages sound about right.
Quote: |
If I connect, say, P4 directly to RST OR RSS, that should reset every cycle on the 4th step, right? Mine doesn't seem to do that. |
The RSS input is used when the gate outputs are wired to a rotary switch so the sequence length can be set. Though it should still work fine if you are using the RST input, thats how mine is set up, no rotary switch, just plug in a patch-cord from one of the gate outs to the RST input.
Ken's description of this module notes the reset behaviour is a bit unusual. Does the up/dwn control work to change the pattern between 1-8? I love using this module to get patterns like - 1234343456787876787678, so the LEDs are stuttering back'n'forth.
Quote: | Incidentally, I've been assuming that the RST is looking for a +5v Gate or Trigger, and the vertical line on the schem above between RSE and +15v means a momentary switch. If either of those aren't the case, it might explain some stuff. |
These assumptions are correct. Any signal over about 2V should work. The momentary switch should be a NO (normally open) type. Obvious I know, but I once bought a bunch of momentary switches and found the shop had dumped NO and NC types into the same tray. The only way to tell the difference was to test them. |
Bodega
Posted: Thu Jul 22, 2010 8:13 pm Post subject:
Thanks Andrew!
So in terms of which voltages go where in your build:
RST - 0v, or the +5v of an individual gate output if it's plugged in
RSS - not connected to anything
RSE - always connected to +15v, except when broken by the momentary switch
Is that right?
When I hardwire RSE to 15V, one of the Up/Down switch's positions locks the sequencer in first position until I flip the switch again. That gives me the impression that it should be an Normally-closed type. Unless, of course, something else is wrong in my build.... |
andrewF
Posted: Thu Jul 22, 2010 8:33 pm Post subject:
Bodega wrote: |
Is that right? |
opposite - RSE connects to +15V only when you press the switch. NO means the switch is open (ie - no connection) until you press it
Bodega wrote: |
Depending upon whether the direction is up or down, the reset point will be #1 or #8. Thats why if you have the reset hardwired on (RSE to +15V), the sequence will stay on #1 until you change the direction with the up/down switch. Then the reset point will be changed to #8, so the sequencer will scurry over there.
sounds like you are almost there  |
Bodega
Posted: Thu Jul 22, 2010 8:41 pm Post subject:
It does!
I'll give it another look tomorrow and see if I can't bridge the gap between it making sense and it making the sounds I want it to make. |
