Burst Generator has negative voltage offset
Page 1 of 1 [4 Posts]
Kent
PostPosted: Thu Jul 09, 2009 3:30 am    Post subject: Burst Generator has negative voltage offset
Subject description: Halp!
Hello all,
I recently purchased a Metalbox-built Burst Generator from a friend. All of the outputs have a -4VDC offset on them. They all work normally besides that and fire off @ +5VDC. I didn't see anything pertaining to this on the CGS site. It is also the only module in the rack that does this.
I've email Metalbox about it but didn't get a reply. Does anyone here have any ideas?
zthee
PostPosted: Thu Jul 09, 2009 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Since the Burst Generator is only attached to 0 and +15V it seems strange that there should be a -4V somewhere in there..
Is the power wired correctly?
Kent
PostPosted: Thu Jul 09, 2009 11:00 am    Post subject: Definitely wired correctly Reply with quote  Mark this post and the followings unread
I just measured the power at the connectors just to be certain.
zthee
PostPosted: Thu Jul 09, 2009 11:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then it's truly strange!
