Audent
Posted: Thu Jul 09, 2009 3:55 pm Post subject:
Calibrating CGS48 VCO Subject description: "Span" acting more like an offset |
I just finished stuffing my vco boards, applied power and all is well! Such a lovely sounding square coming out of this circuit.
So far so good...until i tried to calibrate the vco.
I used Ken's instructions from the CGS site....
so....first I measured pin 7 and adjusted the "Zero" trimmer until i hit 0V....at this point, the vco was somewhere in the 13K range.
next bit of business was to apply 1v to the v/oct input...and use the "Span" trimmer to set the oscillator to play an octave higer with the 1v input....
....now, unfortunately, i don't have the hearing range of a dog- so this was pretty impossible....so i grabbed the tune knob and took the oscillator down to about 500hz and tried to set the octave with "Span". Only the "Span" trimmer is acting more like an offset- it seems to tune the oscillator and CV with or without voltage applied- so my interval always stays the same. Its always about a half step off.
i checked my soldering, connections- i don't see anything glaringly wrong...anyone here have any suggestions on where i might start on this?
much appreciated as always! _________________ http://www.myspace.com/skaneskaneskane Last edited by Audent on Fri Jul 10, 2009 4:16 am; edited 1 time in total |
andrewF
Posted: Fri Jul 10, 2009 2:42 am Post subject:
I can't do it by ear either
have done it with a 'scope and a calculator
but an easy way (for me)
is with a chromatic tuner and a multimeter. |
Audent
Posted: Fri Jul 10, 2009 10:38 pm Post subject:
I just tried the calculator/MM method, and it worked pretty well! I found it difficult to get it PERFECTLY in tune, but this first VCO is pretty good over the 4 octaves i tested it over.
I guess I was running into trouble because I wasn't keeping 0V on pin 7 of IC1. i kept adjusting the coarse tune into a more audible range which, in turn, affected the tuning span (if that makes sense)
Thanks, andrew- your reply helped me quite a bit!  _________________ http://www.myspace.com/skaneskaneskane |
zthee
Posted: Tue Aug 04, 2009 5:11 am Post subject:
Did you do this in the 13K range?
I've got the same problem. With 0V on pin 7 I see 9.821KHz on my frequency counter - and since it won't go beyond 10KHz I can't see what I'm doing. _________________ http://www.thehumancomparator.net/ |
Audent
Posted: Tue Aug 04, 2009 6:15 am Post subject:
| zthee wrote: | | Did you do this in the 13K range? |
Yes- but fortunately my meter reads a high enough frequency. On my two VCO's, I found that I had to turn "SPAN" fully clockwise before they responded correctly to 1v/oct.
thats a tricky problem....maybe a new meter is in order? _________________ http://www.myspace.com/skaneskaneskane |
zthee
Posted: Tue Aug 04, 2009 6:33 am Post subject:
Thanks for the quick reply!
I'll just have to borrow a better meter from a friend  _________________ http://www.thehumancomparator.net/ |
druish
Joined: Jun 23, 2009 Posts: 91 Location: New Paltz NY
Posted: Thu Sep 17, 2009 7:15 pm Post subject:
| what is the calculator/multimeter method? |
andrewF
Posted: Fri Sep 18, 2009 5:27 am Post subject:
i'm curious too
the multimeter is used to ensure you are putting 1V, 2V, 3V, etc into the CV input. I have used an oscilloscope to find the wavelength and then calculate the frequency. Much easier is an electronic tuner. set up the VCO on your favorite note ie - C, with nothing on the CV input. plug in 1V and see if the tuner indicator jumps to the next C, adjust the span trimpot until it does. |
numbertalk
Posted: Fri Sep 18, 2009 5:36 am Post subject:
My Fluke MM has a frequency counter, which really comes in handy for calibrating V/Oct on a VCO, but I am also curious what the calculator is used for as well as if the MM as mentioned here is used to verify the V/Oct input voltage. More info greatly appreciated - always eager to learn new tricks that make calibrating the scaling on a VCO a little easier! It's really easy for me to get wrapped up and spend way too much time suffering over it, especially with the frequency counter and trying to get the frequencies to match up just right for every octave, which of course they won't, so I have to tell myself to be happy when it's off by such a small amount and more than close enough to sound in tune. I'm a little uptight like that  |
andrewF
Posted: Fri Sep 18, 2009 7:03 am Post subject:
on the 'scope you can measure the period of the wave. Lets say Period = x.
So frequency = 1/x
easiest to do on a calculator
of course a frequency meter will be quicker and more accurate, if you have one.
better explanation here |
numbertalk
Posted: Fri Sep 18, 2009 7:20 am Post subject:
Ah right, of course. I do this all the time - duh.
| andrewF wrote: | on the 'scope you can measure the period of the wave. Lets say Period = x.
So frequency = 1/x
druish
Posted: Fri Sep 18, 2009 6:07 pm Post subject:
| wow, just go dne tuning my cgs vco this way. Soo easy and I finally got to use the freq meter on my mm. Thanks. |
rjd2
Posted: Sun Sep 27, 2009 1:18 pm Post subject:
im still having trouble on this. hopefully someone can point me in the right direction? actions:
1-set coarse/fine pots to 12 oclock. trim ZERO to 0v. leave coarse/fine pots at 12.
2-apply 1V,2V, or 3V to CV in. measure V at pin 7 of IC 1.
when i trim SPAN to achieve 1V/oct, if i turn SPAN totally clockwise, the closest i can get is this:
input of 1=1.05V, or 2V=2.1V, or 3V=3.15V. unuseable, basically.
i have confirmed im sending exactly 1,2, or 3V in. even if i turn the coarse pot down to audible frequency, i get the same results. so the SPAN pot works as a span, but with the pot at 0 ohms, i still cant get down to 3V in=3V out at pin 7 of IC 1.
any thoughts? |
druish
Posted: Sun Sep 27, 2009 2:53 pm Post subject:
After setting the voltage to 0V at PIN 7, which you did, you have to connect your meter to the OUTPUT of the OSCILLATOR. This is NOT at PIN 7 of IC1. If I understand correctly this is what you are doing? Connect your meter to the square wave output jack. Then tune the SPAN based on those voltage values.  |
rjd2
Posted: Mon Sep 28, 2009 7:06 am Post subject:
| druish wrote: | After setting the voltage to 0V at PIN 7, which you did, you have to connect your meter to the OUTPUT of the OSCILLATOR. This is NOT at PIN 7 of IC1. If I understand correctly this is what you are doing? Connect your meter to the square wave output jack. Then tune the SPAN based on those voltage values.  |
thanks for this. i was actually talking about measuring VOLTAGE at pin 7, not freq. i have found that measuring voltage at pin 7 seems to be identical to measuring frequency at output: if the same DIFFERENTIAL of CV voltage IN is achieved at pin 7/IC1, then 1V should=1OCT.
my problem is that even with SPAN trimmer at 0 ohms, i still have a differential of CV IN 0V to 3V=0V to 3.2V. that's the lowest it will go, which results in 1V=about 14 semitones, much more than 1OCT.
i am going to experiment w/ reducing the 100k R above IC1 to 90k; i think that if i can achieve a lower resistance at SPAN then i will be into the range of 1V/oct. with SPAN at 10k ohms, im at about 1V=about 16 semitones. will report back. thanks for help! |
druish
Posted: Mon Sep 28, 2009 8:10 am Post subject:
| Ah, I understand what you are doing. If you are trying to measure the voltage change per octave before the exponential converter, i.e. roughly 18mv per Volt of input, then you should attach the scope onto the end of the Tempco (not ground side) because the 56k resistor/Tempco combination is scaling down the voltage going to the linear to exponential current converter. This is the voltage that you want to measure if you want to do it that way. |
rjd2
Posted: Mon Sep 28, 2009 8:41 am Post subject:
ahh, ok.
SO, if i bump the 100K R directly above IC1 down to 90k, i am able to scale to 1v/OCT; this puts me into a workable range using SPAN. finally!
i dont know if this is an artifact of being on +/-15V, or what, but it seems to be the case w/ all 3 CGS 48 VCO's ive built; they all seem to "top out" at about .9V/OCT in stock format. maybe i fudged a value here or there on an R, but it doesnt appear to be the case. all my R's before and after span are exactly to spec. whatever, it works! |
