KORG WAVESTATION & CUBASE
Page 1 of 1 [9 Posts]
viewtopia
PostPosted: Thu Aug 20, 2009 9:37 am    Post subject: KORG WAVESTATION & CUBASE
Subject description: TIMING ISSUES
I have been trying to figure something out for over a year and I guess I'm just slow, so I'm asking for help. I am Using Cubase (3SX) and Korg Wavestation is my favorite plugin instrument. When i use other VST instruments, any patches with a tempo automatically sync to the tempo I have Cubase set at. Not Wavestation. The tempo at which Wavestation plays does, indeed, vary with the tempo at which Cubase is set. but the tempo is not the same. When I raise and lower the Cubase tempo, the tempo of Wavestation raises and lowers as well, but the tempo is not the same. When I record a sequence with Wavestation and then try to play another VST instrument I have to either play perfectly in time or edit each note by hand, as the Wavestation sequence does not correspond with beats/bars as shown in Cubase. I have been all thru the Wavestation manual ad nauseum and cannot find how to adjust the tempo of a preset. Any Ideas??
Audio files: 278
PostPosted: Thu Aug 20, 2009 10:49 am    Post subject: Re: KORG WAVESTATION & CUBASE
some of the wavesequences are not set up to play in time with midi
to get sixteenths you need to edit the step durations to 8
CosmoMcGillicutty
PostPosted: Wed Sep 23, 2009 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
What exactly does that mean?
Audio files: 278
PostPosted: Wed Sep 23, 2009 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
It means that wave sequence step durations that are not 1, 2, 4, 8, 16 etc wont be in time with other things in sync with the same midi clock
CosmoMcGillicutty
PostPosted: Wed Sep 23, 2009 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am having the same difficulty with a sequence that is programmed in an even number of steps (16 steps all with a duration of 8). The wavestation just seems to pick some BPM that is separate yet relative (as in the speed increases and decreases when I make changes to the timing on the DAW) to the internal clock of Cubase 3.
Audio files: 278
PostPosted: Thu Sep 24, 2009 2:06 am    Post subject: Reply with quote  Mark this post and the followings unread
this might actually be due to the timing clock from your DAW not being very accurate
CosmoMcGillicutty
PostPosted: Thu Sep 24, 2009 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
If other devices or soft synths had the same issue I might agree, but like the guy that started this thread I only have this problem with my wavestation. That leads me to believe (provisionally of course) that the problem is with the korg, and not my software. But I don't know, maybe Cubase 3 and the Wavestation EX just aren't 100% compatible. I don't have another DAW to test against, unfortunately....
Audio files: 278
PostPosted: Thu Sep 24, 2009 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, the softsynths won't be affected by midi timing slop, and some devices are better at handling this than others
Have you got any other hardware that sends midi clock that you can use to test the wavestation?
Mooger5
PostPosted: Thu Oct 01, 2009 10:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
IIRC it´s 9 - multiples of 3. So that it´ll also play triplets in time with a 4/4 beat.
