CGS stomp box adaptor issues
JoeMorris
PostPosted: Fri Aug 28, 2009 4:27 pm    Post subject: CGS stomp box adaptor issues Reply with quote  Mark this post and the followings unread
Hi all,
I'll set out my stall immediately - Im basically a novice when it comes to DIY electronics. I've built quite a few pcb based projects but thought Id move into veroboard to try and extend my skills a little.
I have some DIY pedals that I use with my synths and the levels arent ideal so the Ken Stone stompbox adaptor caught my eye, especially as the PCBs are sold out and it's a simple circuit so seemed like the perfect excuse to give a stripboard project a go.
I haven't got a modular so I wanted it to have a built in 15v bipolar supply. I used the power circuit design from the big stomp box adaptor (designed to use a module as a stompbox)
http://www.cgs.synth.net/modules/cgs46_sba.html
and added it to the audio circuit from the small stomp box adaptor
http://www.cgs.synth.net/modules/cgs60_sba.html
(designed to use a stompbox in a modular - essentially my application)....
The problem is, I get terrible hum and distortion (very very loud) - in fact the output pin from the TL071 is very distorted.
I have used a common ground rail for the power supply part of the circuit and the audio part of the circuit - could this be the problem?
Thanks
Joe
