Mooger5
Posted: Wed Sep 30, 2009 2:43 am Post subject:
Re: A low-cost Ghielmetti 10x10 matrix |
| Mooger5 wrote: | Price: 37.50 Euro! For a self-contained mini-modular I think we can´t go wrong with this one
Almost looks too good to be true. Any drawbacks? |
diode pins 4.-EUR/pc, no resistor pins.
with clock/trigger/gate signals i don't see any problem when distributing. for mixing we would need the expensive diode pins (OR-gate).
for CV/audio signals i don't see any problem when distributing. for mixing we would need resistor pins if i am correct. _________________
Tech Buddy at Random*Source |
Mooger5
Posted: Wed Sep 30, 2009 4:47 am Post subject:
Crazy idea, but if the shorting pins are hollow like the diode ones maybe it´s possible to modify them by carefully soldering resistors inside, or if there´s such a thing as conductive superglue, the resistor would go where the insulator in the diode pin is, but in a modified shorting one (much cheaper).
Mooger5
Posted: Wed Sep 30, 2009 5:08 am Post subject:
And another useful option would be to add 10x10 pots and jack connectors to control the input/output levels. It would be an independent module but would not make for a VCS3-type clean layout.
Or, a vertical line of ten pots between two identical patch matrixes. The left matrix would make a direct connection with the outputs and the second a resistive one.
And of course output/input/mod level controls in the synthesizer modules themselves would help too  |
slabman
Posted: Wed Sep 30, 2009 6:34 am Post subject:
one drawback |
| This same matrix came up on another thread. The drawback is the size - 45mm x 45mm - or 1.7 inches on a side. So, the plastic body of those pins must be about 3mm in diameter. You will need to employ the services of trained gerbil to repatch the matrix. Having said that, it could be fun for semi-preset type applications. |
Posted: Wed Sep 30, 2009 6:48 am Post subject:
Re: one drawback |
| slabman wrote: | | ..., the plastic body of those pins must be about 3mm in diameter. You will need to employ the services of trained gerbil to repatch the matrix... |
good point.  _________________
magman
Joined: Feb 04, 2009 Posts: 363 Location: Liverpool, UK
Posted: Wed Sep 30, 2009 9:50 am Post subject:
Re: one drawback |
| fonik wrote: | | slabman wrote: | | ..., the plastic body of those pins must be about 3mm in diameter. You will need to employ the services of trained gerbil to repatch the matrix... |
good point.  |
Man is a tool maker, so its not hard to make a tool for patching the pins.
A simple fix would be to strip the insulation off a bit of cable, something like Cat 5 cable would probably do, push this on to the body of the pin and insert to your hearts content. If you get the size right you can easily patch pins with one bit of tube, something like a biro for patch pins.
If you're anything like me though, it would just be a good excuse to get another tool.
Hmm, pin vice, component grabber, tweezers with curved ends, sod it - get the lot and see which works best.
Regards
Magman |
Mooger5
Posted: Wed Sep 30, 2009 3:39 pm Post subject:
Eheh thanks for all the replies. You know, 3mm sounds thin on paper but in reality isn´t so much that you can´t handle it. CAT5 wire is only 0,5mm.
And you don´t need tweezers or a hamster for that LOL
I´m gonna order one and a bunch of the 16mm grip plugs.
Here´s an edited pic from sequencer dot de
slabman
Posted: Thu Oct 01, 2009 5:07 am Post subject:
You guys! |
Just what do you have against hamsters and gerbils? You're trampling on a noble tradition. Haven't you heard of Beaver and Krause? Don't you know that EMS stood for Electronic Meerkat Studios? Jean-Michel Jarre's roadcrew consisted entirely of flying squirrels. Oh well, I've tried my best. Go ahead and tweeze those pins. Just don't say I didn't warn you when you sneeze on stage and your patch flies into the audience. And all for the sake of a gerbil.
Seriously though - let us know how you get on. |
Mooger5
Posted: Thu Oct 01, 2009 7:08 am Post subject:
Well, there´s a distributor right next to where I work but I just let the mouse do the shopping. As soon as the Guinea Pig arrives I´ll start the experiments and post the results  |
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Thu Oct 01, 2009 12:26 pm Post subject:
Subject description: DIY alternative to Ghielmetti matrix |
How about putting together a patch matrix using standard 3.5mm or 1/4" phone jacks? You would run the 'vertical' connections to the ring connection and the 'horizontal' signals to the sleeve. Then put a resistor (mixing audio or control voltages) or a diode (mixing gate signals) into a phone plug (color coded with some colored heat shrink) between the ring and sleeve pins and bang, zoom, bobsyeruncle, you have a patch matrix. Yes, it would be bigger than the matrix shown, in fact it would be bigger than most matrix boards, but it could still be a reasonable size (especially if made with 3.5mm or even 2.5mm jacks) and you could build it as big or small as you wanted. BTW, not my original idea. I'm pretty sure someone proposed this on SDIY a couple of years ago, but I've never seen anybody implement one of these.
Tim (besides, my cats would eat any patching gerbils) Servo |
Joined: Apr 03, 2004 Posts: 24544 Location: The Netherlands, Enschede
Audio files: 299
Posted: Thu Oct 01, 2009 3:56 pm Post subject:
| Tim Servo wrote: | | but I've never seen anybody implement one of these. |
Rob Hordijk builds 'm with 1/4" jacks ... Dennis posted a picture here but can't find it right now. The interesting thing is that all kinds of synth modules can be inserted, not just resistors. _________________ Jan
Mooger5
Posted: Thu Oct 01, 2009 4:33 pm Post subject:
Yes that one is a good alternative. But the Ghielmetti besides being already made is just suitable for my purposes. It´s for a mini-modular, with a small number of modules that most of the time will be connected like in a commercial hardwired synth, with the advantage of rearranging them for the odd noise or two every now and then. Assigning eg2 to vco1, 2 or both, as an example...
Yes, the utile area in that patchbay is minuscule, but being optimistic I say it´s not worse than a breadboard (10 pinholes against 11 in a 28mm line).
Now what is surreal is that I´m not getting a response from Ghielmetti so I spoke on the phone with some importer and they said I´d pay around 500 Euros at Customs for the thing, AFTER I told them I just want one unit for a hobby.
I´ve ordered from outside the UE and I´ve paid the usual duties. There´s no way such a cheap item would be charged that amount, even coming from Switzerland. Last edited by Mooger5 on Fri Oct 02, 2009 10:31 am; edited 2 times in total |
slabman
Posted: Fri Oct 02, 2009 3:03 am Post subject:
Importer |
@Mogger5 -
is this the importer you tried
Ghielmetti in Portugal
Pinto Basto Electrotecnia
Av 31 de Julho, 3-1° Esq
1200'-480 Lisboa
Tel: +351 21 397 20 41
Fax: +351 21 397 25 95
E-mail: moura.tendeiro@pintobasto.pt www.pintobasto.pt
I found the above on the Ghielmetti website |
Dave Kendall
Mooger5
Posted: Fri Oct 02, 2009 8:50 am Post subject:
Re: Importer |
| slabman wrote: | @Mogger5 -
1200'-480 Lisboa
I can´t legally remember... some sales rep from nowhere advised to cancel my order at Ghielmetti so it would be better for me to buy directly from them to avoid the high taxes. What a sales speech lol. There must be a crisis going on.
But it could have been my imagination. Probably a real conversation never happened. The optical mouse saw my password and typed all the gibberish. Mmmmmmm you dirty rat.... |
Funky40
G2 patch files: 5
Posted: Fri Oct 02, 2009 4:25 pm Post subject:
| Mooger5 wrote: |
Speak with Martin Holliger.
He is a EE at Ghilmetti and he runs his own "Synthesizermuseum" ( having (nearly) everything !!! ), and he is the developer and builder of the Airbourne (modular) Synth, made with FPGA.
Speak with him , he is a VERY gentle Guy |
Funky40
G2 patch files: 5
Posted: Fri Oct 02, 2009 4:31 pm Post subject:
| fonik wrote: | | Mooger5 wrote: | Price: 37.50 Euro! For a self-contained mini-modular I think we can´t go wrong with this one
I have one or two small 10x10 Ghielmettis with resistorpins that look exactly the same. I guess the price was also in this range.
Yup, 4€ per pin ( i got resistor pins )
I also have some small 10x10 with diodepins, those are red and where from a surplus sale (older ghilemetti product 9
was 22$ WITH the diodepins  |
Mooger5
Posted: Fri Oct 02, 2009 4:52 pm Post subject:
| Funky40 wrote: |
Thank you. I will  |
Mooger5
Posted: Fri Oct 02, 2009 5:07 pm Post subject:
| Funky40 wrote: | | fonik wrote: | | Mooger5 wrote: | Price: 37.50 Euro! For a self-contained mini-modular I think we can´t go wrong with this one
What do you think of the patchbays? Are they easy to work on? |
Funky40
G2 patch files: 5
Posted: Sun Oct 04, 2009 12:42 pm Post subject:
| Mooger5 wrote: | | What do you think of the patchbays? Are they easy to work on? |
i never used one , nothing built
i lost interest in the audiosignal matrix,
after having now quite some experinece with patching my modular i don't see any advantage to patch over a matrix.
But might be another thing on a compact Synth.
the diode matrix i find still very interesting.
The idea was to chain 8 of them and drive them with a 64 stepp triggersequenzer.
This would give a triggersequenzer with 8rows with 64 stepps .
one day...........and in the meantime i'm using a MFB Sequenzer
my guess is that the small patzchbay work if you don't have to patch to dense.
the triggerstuff might be good.
For audio/CV routings the bigger(grid) units might be the better choice
( i had some here too, as i organised the groupbuy back then )
the patchbay with bigger grid looked very nice ! |
ericcoleridge
Posted: Sun Oct 04, 2009 12:59 pm Post subject:
I believe I own a couple of these 10x10 mini patch bays... I mean, I have a couple, and I think they're the exact same ones as above.
I would ask for a sample before buying a lot of them. They're quite small and delicate, and IMO, are not perfectly suitable for any kind of frequent patching/re-patching. This is besides the resistor issue... there's that too.
the ones I have, the pins are very easy to break, they're very delicate. The patchbay itself is very small, the holes are tiny. I'm thinking I'd like to use it someday on a gate seq type thing... but can't see it working well as a full patchbay ala EMS, unfortunately. |
Tasmanian Alkaloid
Joined: Jun 29, 2008 Posts: 116 Location: Isle De Mort
Posted: Sun Oct 04, 2009 7:56 pm Post subject:
| Funky40 wrote: | | Mooger5 wrote: |
That Airbourne synth is insane! |
Mooger5
Posted: Mon Oct 05, 2009 4:06 pm Post subject:
Well if the pins break so easily, it´s a significant drawback. I´ll give up on this one.
Funk40, was there a thread about the group buy you mention? I couldn´t find it using the search function.
Thanks all. |
