praecox
Posted: Thu Oct 01, 2009 7:09 am Post subject:
Nord Rack 2 Hwo to tune in perfect 5th? Subject description: semitone knob lights when reaches an octave |
hi to all,
i would like to know your experience in subject of tuning nord rack2.
tuning the OSC to the other values then octave it is not that easy.
how you guys make it? (ok, i know the story about the golden ears... )
thnx, j |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Oct 01, 2009 7:41 am Post subject:
AFAIK there is no light that blinks when reaching the perfect 5th
Using your ears, sorry, or something which gives the pitch of the fifth, and just fiddle...
No, better to make a Morpf: assign to the SemiTone and make a range from the first blink to the second blink. (one octave) Now you are able to set the semi tones by the wheel. This ins much more acurate. Than adjust using the FineTune
You can set the SemiTone also using it's own knob, which is a little more delicate than using the Wheel. Use [Shift+LFOwave form] to read the value in the display. You cant use the LCD reading out for the Wheel, because you need to know what it would be on the SemiTone. Do the same when adjusting the FineTune...
And save, of course
Wout |
praecox
Posted: Thu Oct 01, 2009 8:01 am Post subject:
hi, thnx for the quick answer
what do you mean by Shift+LFO1? does it affect semitone pitch?
thnx
j |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Oct 01, 2009 10:16 am Post subject:
| praecox wrote: | | ... what do you mean by Shift+LFO1? does it affect semitone pitch? ... | No, it shows a figure of the value set by the knob you are using at the moment, which is rather nice when you want to set parameters to the same value, like the AmpEnv and FilterEnv or the Rate of the two LFO's. Also very handy when you want to set it to a known value. Beware, as soon as you tweak a knob the value jumps to the position the knob is at that moment.
You want to set Osc2 in a perfect fifth to Osc1, as I understand you question. The SemiTone knob is divided into 12 steps, but that doesn't mean the seventh step up is the 'perfect' fifth. Maybe you have to adjust using FineTune. When using the [Shift+LFO1wave form] you see the value in the LCD and you can write it down to remember, so the next time to set it you know what to do. It is just an advice, no command
Wout |
