Env end AND clock
Page 1 of 1 [2 Posts]
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Thu Oct 07, 2004 2:02 pm    Post subject: Env end AND clock Reply with quote  Mark this post and the followings unread
settle wrote:
i want the note sequencer to only send a change to the pitch on my oscillators when i trigger the envelope, so when i have a long decayon the envelope, the pitch of the oscilator doesnt change during the decay.
I think this patch is a simple solution to your described problem. Run the clock and the "end" output of the envelope into an AND gate and it achieves the effect you described when twiddling the decay knob.
The clock pulse will only trigger the env when the Decay reaches zero (outputs a 1) AND the clock pulses (outputs a 1).
endandclock.pch2
Pitch seq that modulates osc pitch only when env has decayed
 Filename:  endandclock.pch2
 Filesize:  1.45 KB
 Downloaded:  1850 Time(s)
Audio files: 213
PostPosted: Thu Oct 07, 2004 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good patch for illustrating a principle.
