Is My Nord Micro Modular Braken
Page 1 of 1 [2 Posts]
dougguod
PostPosted: Fri Oct 16, 2009 7:39 am    Post subject: Is My Nord Micro Modular Braken
Subject description: Note off messages not being recived
I think my nord modular may be broken and wanted to find if anyone has the same problem or a solution?
I have a very simple patch with a oscillator a filter and an envelope. i have mapped the the adsr to midi cc number 105 to 108. I am send my midi through logic from my USB O2. I find that when I open the patch and play notes on my O2 the adsr acts as suspected but as soon as i change any Envelope parameter with my O2 cc's the adsr shows that there is a constant note going to the patch, when this happens say the note is stuck on C2 and then play D2 it plays D2 normally but when i release D2 it goes back to making a constant note on C2. is the patch corrupt or is my Micro broken.
iI also find that when i delete the keyboard in and replace it it acts normally until i use my O2 to change an ADSR parameter it gets stuck again.
thanks
Doug
Audio files: 297
PostPosted: Fri Oct 16, 2009 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Doug.
Sort of hard to tell .. could you post the patch here? That would make it easier ... its not likely that the synth would be broken in such a way that it would just not receive note offs.
