Digital noise pot
Page 1 of 1 [4 Posts]
LetterBeacon
PostPosted: Mon Oct 19, 2009 1:32 pm    Post subject: Digital noise pot Reply with quote  Mark this post and the followings unread
The schematic specifies a 25k pot for the Speed pot. Can I use a 20k?
lanxe
PostPosted: Mon Oct 19, 2009 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would think so, but you might not get the full range that a 25K would offer.
Just a guess....somebody smarter than me chime in.
andrewF
PostPosted: Mon Oct 19, 2009 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
20k will be fine.
The speed pot is working a voltage divider. Usually when a pot is used as a divider you can get away with a wide range of values, say 10k to 100k.
On this circuit the 1k resistor between +V and the pot will make a very small difference if you use a smaller valued pot (20k) but not enough to worry about.
LetterBeacon
PostPosted: Wed Oct 21, 2009 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys!
