ext audio in patch "M-Resonator"
Page 1 of 1 [5 Posts]
wave
PostPosted: Fri Jan 01, 2010 4:11 pm    Post subject: ext audio in patch "M-Resonator"
Subject description: inspired by the jomox analog filtermachine
Here comes a G1-patch inspired by the jomox m-resonator - it`s not a 1:1-copy and it is also version one at the moment - I`ve tried to emulate (what I understand Very Happy ) what this machine does with audio - also this machine isn`t easy to use - the G1 gives better control (my personal opinion) and more opportunities (fact Very Happy ) ...
I`ve tested the patch with a simple audio-loop (also attached) - start your test with knob number 6 (morph one), then try the others ... Very Happy
Comments and useful additions welcome ! ...
M-Resonator.pch
 Filename:  M-Resonator.pch
 Filesize:  3.27 KB
 Downloaded:  574 Time(s)
loop.wav
 Filename:  loop.wav
 Filesize:  357.59 KB
 Downloaded:  880 Time(s)
klangumsetzer
Audio files: 37
PostPosted: Fri Jan 01, 2010 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello wave,
thank you, will try to test this soon.
best regards
eike
wave
PostPosted: Sat Jan 02, 2010 3:33 pm    Post subject: "knob info" Reply with quote  Mark this post and the followings unread
"knob info"
left channel:
knobs 1-5 and 13-15
(1&4 = Env Follower / 2 = Amount / 5 = FilterFreq / 6 = Res /
13 = Cross 1 / 14 = Feedback / 15 = Cross 2)
right channel:
knobs 7-11 and 16-18
(dto.)
knob 6 = red morph, knob 12 yellow morph
Have fun ! ...
http://www.myspace.com/intense-blue
1x G1 key / 1x G1 rack / 1x G2 Key ... (waiting for G3 *g*)
wave
PostPosted: Sat Jan 02, 2010 3:45 pm    Post subject: M-Resonator 2.0 Reply with quote  Mark this post and the followings unread
... and here is a second version: M-Resonator 2.
I've changed the first filter (controlled by the EnvFollower) to enable more options and added some modulation cords ...
The attached version includes radical settings to show whats possible ...
And again comments and useful additions welcome !
M-Resonator 2.pch
 Filename:  M-Resonator 2.pch
 Filesize:  3.52 KB
 Downloaded:  559 Time(s)
DanielW
PostPosted: Mon Jan 11, 2010 3:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you! A useful effect indeed.
